How Does a Bullet Impact Affect the Angular Velocity of a Door?
  • Thread starter Thread starter sp3sp2sp
    Bullet
The discussion centers on calculating the angular velocity of a door after being struck by a bullet using principles of conservation of angular momentum. A 10 g bullet traveling at 370 m/s embeds itself in an 8.0 kg door, which is 0.80 m wide. The correct formula to determine the angular velocity (ω) is derived from the conservation of angular momentum, specifically using the equation ω = (3mv) / (ML^2). The initial calculation was incorrect due to a misunderstanding of the conservation principles, as linear momentum and angular momentum cannot be equated directly.
  • Understanding of conservation of angular momentum
  • Familiarity with the moment of inertia (I) for a slab
  • Basic knowledge of linear momentum concepts
  • Ability to perform calculations involving angular velocity (ω)
  • Study the conservation of angular momentum in collisions
  • Learn about moment of inertia calculations for various shapes
  • Explore the relationship between linear and angular momentum
  • Practice problems involving angular velocity calculations in similar scenarios
Physics students, educators, and anyone interested in mechanics, particularly those studying rotational dynamics and collision problems.
sp3sp2sp
A 10 g bullet traveling at 370 m/s strikes a 8.0 kg , 0.80-m-wide door at the edge opposite the hinge. The bullet embeds itself in the door, causing the door to swing open.
What is the angular velocity of the door just after impact?
Express your answer to two significant figures and include the appropriate units.
use conservation of momentum for slab about edge: linear momentum = angular momentum
mv = Iw
I = (1/3)ML^2 (for a slab)
w = (3mv) / (ML^2)
(w = omega)
3. The Attempt at a Solution
w = (3mv) / (ML^2)
w = (3* 0.01kg * 370m/s) / (8.0kg * 0.80kg^2)
w = 2.167 = 2.2 rad/s
= wrong
cant see what I am doing wrong, thanks for any help
o_O
Linear momentum and angular momentum are different quantities with different units. They cannot be set equal. In this case, only one of those is conserved.
Hint: Use conservation of angular momentum. (What's the angular momentum of the bullet just before impact?)
bullet doesn't have any angular momentum before impact So Iw = 0?
Sure it does (about the door hinge axis). Read this: Angular Momentum of a Particle
sp3sp2sp said:
So Iw = 0?
No.
  • · Replies 20 ·
16K
  • · Replies 88 ·
24K
12K
