How Many Logs Are Needed to Build a Raft for Four People?
The discussion centers on calculating the minimum number of logs required to construct a raft capable of supporting four individuals, each weighing 80.0 kg. The density of the logs is 725 kg/m³, with a radius of 0.08 m and a length of 3.00 m, resulting in each log weighing approximately 43.7 kg. The buoyant force is determined by the weight of the water displaced by the submerged logs, and the equilibrium condition requires balancing the total weight of the logs and passengers against the buoyant force. The final equation to solve for the number of logs (n) is F(p) + n*F(l) = 0, where F(p) is the force from the passengers and F(l) is the net force from each log.
  • Understanding of buoyancy principles and Archimedes' principle
  • Basic knowledge of physics, specifically force and weight calculations
  • Familiarity with density and volume calculations
  • Ability to solve linear equations
  • Study buoyancy calculations in fluid mechanics
  • Learn about Archimedes' principle and its applications
  • Explore density and volume relationships in physics
  • Practice solving equilibrium equations in mechanics
Students in physics, engineering professionals, and anyone interested in practical applications of buoyancy and force calculations in real-world scenarios.
linemanpete
I have run into a problem and am completely stumped after. Help me before i pull my hair out.
What is the smallest number of whole logs (p (density) 725 kgm^-3) r= .0800m l=3.00m that can be used to build a raft that will carry four people each with a mass of 80.0 kg.
so using (pi*r^2*l)*725 i found the mass of each log to be 43.7 kg
BUt beyond this i run into huge headaches by trying to derive something that can include X # of 43.7 kg logs in relation to buoyant force and Weight
please help
The buoyant force on the logs is the weight of the water they displace and the condition of minimum buoyancy will be met if the logs are just completely sumberged with the passengers just at the surface of the water. All you have to do is balance all the forces (weight of the logs + passengers against the buoyant force).
Find the force generated by the 4 people on the raft, as well as the net force per log. That should set you on the right course.
I have some questions about this problem too. Okay, I've got that:
Force of buoyancy = Weight (of logs) + Weight (of load/people)
Since each person's mass was 80.0 kg and there are 4 people, I went
Weight (load) = (80.0kg) x (4) x (9.81m/s^2) = 3139.2 N (Force of the load)
and the force of each log is
(density of log) x (volume of log) x g = (725kg/m^3) x (pi) x (0.08m)^2 x (3m) x (9.81m/s^2)
= 429 N
But I'm not really sure what to do next...
Once you have the total force applied by the people on the raft as well as the net force created by each log (the difference between mg and the buoyant force), you need to find the number of logs that will make the force applied by the people + the net force of all the logs = 0
F(p) = force created by passengers
F(l) = net force created by each log
F(p) + n*F(l) = 0
Solve for n.
15K
9K
