Bypass Capacitor Placement for Optimal Power Supply Performance
  • Thread starter MissP.25_5
    Capacitor
9 replies · 3K views · last reply
MissP.25_5
Hi,
I would like to know how to insert a bypass capacitor in parallel with the power supply.
I drew some GREEN lines as jumpers and BLUE line as bypass capacitor for you guys to check if that's the correct way to do it.
NOTE: Ignore the jumpers, just look at the lines I drew with MS paint.
  • Schematic of a 74LS85 magnitude comparator (labelled 85) feeding a 74LS393 counter (labelled 393), with ELVIS outputs D0 to D3 and a function generator input FG on the CK pin; 5V supply with ground on comparator inputs A<B, A=B and A>B.
  • Photo of a breadboard circuit with two ICs, many coloured jumper wires, and hand-drawn annotations: a blue capacitor symbol labelled CAPACITOR and green lines labelled JUMPER 1, JUMPER 2 and JUMPER 3.
Your capacitor appear to be connected between 5V and 5V. Should be connected between 5V and 0V as close to the 5V pin on the IC as possible.
On this type of breadboard (I believe) you have 5V (red) and 0V (blue) rails. Unless the circuit is particularly sensitive you can just plug the cap into the rails, no jumpers required.
PS: On some breadboards not all the rails are connected to 5V and 0V. Sometimes they aren't connected at the ends (the idea being to allow you to create a 12V rail or similar). Just check any you use are connected on your breadboard.
  • Photo of a breadboard circuit with red and blue jumper wires, two ICs, and a capacitor, with red arrows labelled 5V and 0V ? and blue arrows labelled Caps pointing to the capacitor leads near the power rails.
On this type of breadboard you have 5V (red) and 0V (blue) rails. Unless the circuit is particularly sensitive you can just plug the cap into the rails, no jumpers required.
I thought that to connect the capacitor in parallel with the power supply (5V, the red rail) I should connect it like that. The IC85 has its power supply on its 16th pin and the IC393 has its power supply on its 14th.
Oh, so I need two capacitors? Can I just use one capacitor and connect the capacitor to the two IC's with jumpers instead? By 0V you mean ground, right?
Yes. Good practice is one per IC. I have added them to your circuit drawing...
  • Schematic of a 7485 magnitude comparator (labelled 85) wired to a 74393 counter (labelled 393), with ELVIS outputs D0 to D3, a function generator input FG on the counter clock, 5V supplies and 0V decoupling capacitors on each chip.
I have to use 0.1μF capacitor and I am only provided one, but not two.
Why do we need to ground the capacitor, too?
Let me re-draw it with only one capacitor and the grounding.
Just to clarify...
One per IC
Located close to the 5V pin on the IC
Connected between 5V and 0V/Ground
Note that 0V isn't always Ground but in your case they are the same node.
If you only have one capacitor put it on the most sensitive device.
Edit: Since there isn't much to choose between them I would put it on the 5V and 0V rail between the two devices and connect jumpers from that rail to both devices.
Is this ok?
  • Photo of a breadboard circuit with two chips, red, black, yellow and blue jumper wires, a blue capacitor marked CAP, and red handwritten arrows labelled 5v pointing to the power rails.
Yes that's what I'd do if I only had one cap. You have the cap connected to the 5V pins on both ICs by nice short wires. I would also connect the 0V pins on the ICs directly to the 0V rail that the new capacitor is plugged into by short wires.
All this may not make much difference to the operation of the circuit but it's good practice.
