C++ and Radial Probability Density
35 replies · 8K views · last reply
erok81
In a neutral hydrogen atom, the electronic ground state 1s, and excited state 2s, are given by wave functions
ψ1s = 1/π1/2 1/a3/2 e-r/a
ψ2s = 1/(32π)1/2 (2-r/a)2 e-r/(2a)
where "r" is the radial distance to the nucleus, and "a" is the Bohr radius.
Write a C++ program hatom.cc that calculates the radial probability density,
Pr(r) = 4πr2ψ*ψ,
from r=0 to 10 Bohr radii (r=10a) with a stepsize of dr=0.01a. At each radial step, print out three columns to standard output: r (units of Bohr radii), Pr(r) for the 1s state, and Pr(r) for the 2s state.
To check your output, confirm that your values of Pr are such that the integral of Pr out to 10a gives you something close to unity. (An integral may be crudely approximated using summation of the function at a series of uniformly separated points times the separation (delta x) between adjacent points)
None.
I can see where to get started here, but need a little help understanding the problem.
This part loses me...from r=0 to 10 Bohr radii (r=10a) with a stepsize of dr=0.01a. At each radial step, print out three columns to standard output: r (units of Bohr radii), Pr(r) for the 1s state, and Pr(r) for the 2s state.
I need a for loop that will calculate r=0 to r=10 with an interval of 0.01a. First I am not sure how to make the loop calculate in steps, but can probably figure that. It's the r=10a part that I don't get. I know from my physics classes that the Bohr radius is given by [itex]a_0 = \frac{\hbar}{m_{e} c \alpha}[/itex]. Does it look like you run loop as 0, 1a, 2a, 3a,...10a? With a given by my Bohr radius formula?
I'll probably need a little help with the C++ part as well after I get past this part.
Pr(r) = 4πr2ψ*ψ,
None.
You can set a constant to the value of the Bohr radius, which wikipedia gives as 5.2917721092(17)×10−11 m.
Here's a loop that I think will do what you want.
Code:
const double Bohr_radius = 5.2917721092E-11;
for (r = 0.0; r <= 10 * Bohr_radius; r += .01*Bohr_radius)
   // Do something
Oh nice. That also helps me setting constants. I've seen those on a few examples during my search to solve this problem. Good to actually see how to use it.
When I am calculating something like these, is it possible just to type it out like you would in Maple or Mathematica? It seems to me that the first column r shouldn't need much more than the loop since there isn't much to calculate there?
What I was going to try to do was get the first column, r, to work and then move on to my other columns.
For the first column I tried a couple things for the //do something. I can only get it to output zeros.
Pr(r) = 4πr2ψ*ψ,
None.
Maybe, if you could elaborate as to what you want to be calculated in detail. That is you give mathematical equivalents of what variables will be calculated, I can give it a try in java.
Well for my first column I am trying to get the values of r displayed for each of the step levels. At least that is what I am assuming is to be done.
So 0.00a, 0.01a, 0.02a, 0.03a...9.98a, 9.99a, 10a. Where a is the Bohr Radius.
Please elaborate like the following example :
3 quantities to be calculated : var1 = blah blah
var2=blah blah
var3 = mathematical expression
What are to be output and, before that the formulas.
For my first run I am only trying to get var 1 to work. Nothing with the other two yet. Since they are going to be laid out in three separate columns, I was just going to try to get the easier of the three sorted out first.
So using that for loop above (which I can't get to display anything but a constant stream of 0's) I just need to calculate 0.00a, 0.01a, 0.02a, 0.03a...9.98a, 9.99a, 10a. Where a is the Bohr Radius or 5.2917721092E-11. It seems to me that loop would do the trick, I can't figure out what to put in the //do something field. I've tried r, r*a, etc etc. It's my lack of understanding I guess that I don't know what needs to be under the loop.
If you want to see something displayed, you need to use something to do output. In C++, the count object and the >> operator are typically used.
You said earlier that you are getting a stream of 0s, which implies that you know how to do output. Please show us the code you are using, and we can figure out why you're getting 0s instead of what you want.
When you show us the code here, put a (code) tag at the beginning and a (/code) tag at the end. Use brackets, though [], instead of parentheses.
Pr(r) = 4πr2ψ*ψ,
None.
As far as what I have learned by now :
(1) For the Probability density function of H atom in 1s : The most probable position of the electron is one Bohr Radius away from the Nucleus, that it unifies to one "1" when the radius to be calculated is equal to Bohr's Radius ( it is a constant and you do not need to calculate that )
(2) You can either go integrate
http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/hydrng.html#c1
the first integral on the linking page, which requires that you use RIEMANN SUMs
OR
evaluated form where you can plug in the distance the electron's from the Nucleus and find from zero to r
For 2s, I need the equation, but the Logic applies
In your program , You need Loops
the likes of which are alike to the following java piece of code
Code:
for (  double i=0.0;i<=Bohr*10.0;i+=0.01*Bohr;
And before that declare Bohr in the following Fashion :
Code:
double  Bohr=5.2917721092*Math.pow(10,-11.) ;
Code:
This for loop will not compile. Post #2 shows one that can be used.
Yes, when you leave the blanks between
blank, but I am not allowed to put the code that fits in between am I ( even if it's in java ) ?
Mark44 said:
If you want to see something displayed, you need to use something to do output. In C++, the cout object and the >> operator are typically used.
I got the zero part figured out finally and also learned a couple things in the process.
I was defining r as int r - which come to find means integer. Since my value was so small it showed up as zeros. I never let it run long enough to get close to one.
Now I have it changed to double r which gives me a value!
So now it's just adding columns (?) and defining two more calculations...at least I think.
To display the r column I have the following code:
Code:
#include <iostream>
#include <cmath>
using namespace std;
int main()
  double r;
  for (r = 0.0; r <= 10; r += .01*Bohr_radius)
      cout << r << endl;
  return 0;
Besides the columns, I think two more cout's along with their assigned values (like the double r) should do it. If I have the one for loop can I apply three different couts that will run off of the one loop?
That wasn't the problem. It was this line.
Code:
If you can't spot what's wrong with this, then you shouldn't be offering programming help.
Code:
Yes OK I forgot (rather skipped my eye ) to end the paranthesis and omit the ;
I really do not know why you say like that, Could not it be that my eyesight is poor ??
And I have the fully working code, btw.
This was post #2.
Code:
   // Do something
Is your post an improvement over what was already in this post?
stallionx said:
for ( double i=0.0;i<=Bohr*10.0;i+=0.01*Bohr)
Mark44 said:
This was post #2.
Yes and No, you are writing in C++, I am writing in Java.,
Please refer to my Posts #9 and #11
So I am trying to learn, trying to help.
OK, you are the Professional but Can't I contribute, too ?
A for loop is pretty much the same in C, C++, Java, and C#.
Yes, I saw those posts, and commented on the code you had in them.
And we appreciate members who help others.
You are certainly welcome to contribute. My point is that the code you provided was essentially a duplicate of the code in post #2, except that it had some pretty obvious errors. I recognize that all of us make mistakes, and that none of us are perfect, but you should take a quick look at what you're about to post, and fix really obvious problems.
Code:
#include <iostream>
#include <cmath>
int main()
  double r;
      cout << r << endl;
  return 0;
I think the top line of the for loop should be
Code:
You can add two more columns, not by putting in another cout statement, but by adding some more things to display in your one cout statement. Something like this:
Code:
cout << r << "\t" << expression_2 << "\t" << expression_3 << endl;
The "\t" strings are strings that contain a tab character, for spacing.
expression_2 and expression_3 are the other things that you want to put on the same line. I don't remember you saying what else you wanted to display, so you'll need to figure out what these represent (and you should use your own variables).
This is what I am finding...this probably isn't the best/cleanest method, but I think it should work? rather than creating extra variables, I was just going to type it all out on one line. Since neither expression has imaginary numbers, I'm just going to square it.
Original problem:
ψ2s = 1/(32π)1/2 1/a3/2(2-r/a)e-r/(2a)
Pr(r) = 4πr2ψ*ψ,
For r we have that taken care of.
For my expression 2 (I didn't type this out in code. I'll to figure that out)
4πr2(1/π1/2 1/a3/2 e-r/a)2
And similarly for expression 3
4πr2(1/(32π)1/2 1/a3/2(2-r/a)e-r/(2a))2
Where a will be replaced by my Bohr_radius constant.
Will that work, or do I need to something other than that?
And from what I can gather say I wanted to write x2 in C++. That would go as pow(x,2)? I tried that in my program as a test, but it didn't work. Is there something I need to call out in the top?
Okay, yeah. That isn't even close. Here is what I tried. I haven't done expression 3 since I wanted to get through expression 2 first. This pumped out almost half a page of errors.
Code:
#include <iostream>
#include <cmath>
int main()
  float r;
  for (r = 0.0; r <= 10*Bohr_radius; r += .01*Bohr_radius)
      cout << r << "\t" << 4*3.14159265*r*r((1/(pow(3.14159265,0.5))*(1/(pow(Bohr_radius,1.5))*exp((pow((-r/Bohr_radius)))))),2) << "\t" <<  endl;
  return 0;
One of the errors mentioned I need to call pow(double). So I know I must be missing a few things. I think I have all of my parenthesis in place okay.
I don't see why it wouldn't work.
To use pow(), you need to include the right header file, math.h.
#include <math.h>
If all you're doing is squaring a number, it's simpler just to multiply the number by itself, as x * x.
For square roots, there is the sqrt function. You can get pi this way, using the acos function (arccosine):
pi = acos(0.0);
1. Calculate pi once, and store it in a variable.
2. Calculate your expressions and store them in variables. That way your count statements will be much shorter.
3. Operations (such as multiplication) that are implied in math expressions are NOT OK in programming. I can write 2x or 3(a + b) in a math context, but I have to write 2*x and 3 * (a + b) in most programming languages.
Maybe my error is something else then. I agree. Where I had r2 I just typed out r*r like you suggested. However I have quite a few with fractional powers.
Good point on the sqrt's. I'll replace those and see how it goes.
I was also going to declare pi as a constant at the top instead of continually typing it in. Although your method looks pretty easy as well.
I swap some stuff around and see how it goes. Do you know if there is something like sqrt for my 3/2's power?
You beat me to posting. This post applies to your first post.
2. Calculate your expressions and store them in variables. That way your cout statements will be much shorter.
Okay, I missed that one. You'd think with all of my Maple work I'd have those down. Guess not.
I haven't shortened my expressions yet. I want to get it to work before I start messing with it. I definitely will though.
These are the errors I am getting.
hatom.cc: In function 'int main()':
hatom.cc:15: error: no matching function for call to 'pow(double)'
/usr/include/iso/math_iso.h:63: note: candidates are: double pow(double, double)
And this is my code.
Code:
#include <iostream>
#include <cmath>
int main()
  float r;
      cout << r << "\t" << 4*3.14159265*r*r*(pow((1/(sqrt(3.14159265)))*(1/(pow(Bohr_radius,3/2)))*(exp(pow(-r/Bohr_radius))))),2) <<  endl;
  return 0;
I don't think I am missing any * and my parenthesis should be straight.
#include <math.h>
pi = acos(0.0);
Sir, isn't Pi=acos(-1.0) ?
Or
Pi=2.0*acos(0.0) ?
Mark44 said:
For the 3/2 power, use pow. There's no special function (like sqrt) for this power.
Can't we, here, multiply x*sqrt(x) ?
Okay, I cleaned it up a little bit and have this...
Code:
#include <iostream>
#include <cmath>using namespace std;
int main()
  float r;
  const double Pi = 3.14159256;
      cout << r << "\t" << 4*Pi*r*r*(pow((1/(sqrt(Pi)))*(1/(pow(Bohr_radius,3/2)))*(exp*(pow(-r/Bohr_radius))),2) <<  endl;
  return 0;
Now...my errors are looking better. Now I only have the following. But I can't see where they come in.
hatom.cc:14: error: expected ',' or ';' before 'for'
hatom.cc:14: error: expected `;' before ')' token
For some reason I am getting these errors. The one above was a fluke.
prog.cpp: In function ‘int main()’:
prog.cpp:18: error: no matching function for call to ‘pow(double)’
/usr/include/bits/mathcalls.h:154: note: candidates are: double pow(double, double)
/usr/lib/gcc/i686-pc-linux-gnu/4.3.4/include/g++-v4/cmath:380: note: long double std::pow(long double, int)
/usr/lib/gcc/i686-pc-linux-gnu/4.3.4/include/g++-v4/cmath:376: note: float std::pow(float, int)
/usr/lib/gcc/i686-pc-linux-gnu/4.3.4/include/g++-v4/cmath:372: note: double std::pow(double, int)
/usr/lib/gcc/i686-pc-linux-gnu/4.3.4/include/g++-v4/cmath:367: note: long double std::pow(long double, long double)
/usr/lib/gcc/i686-pc-linux-gnu/4.3.4/include/g++-v4/cmath:363: note: float std::pow(float, float)
prog.cpp:18: error: expected `)' before ‘;’ token
I have zero idea what that stuff is. :smile:
