What is causing my C++ program to truncate Euler's number?
  • Context: C/C++
  • Thread starter Thread starter Superposed_Cat
    C++
The discussion revolves around a C++ program intended to calculate Euler's number, focusing on issues related to truncation of decimal points in the output. Participants explore potential causes of this truncation, including data types and division methods, while providing suggestions for code improvements.
  • One participant notes that the factorial function returns an integer, suggesting it should be cast to float to avoid truncation.
  • Another participant points out that using 1/factorial will result in integer division, recommending the use of 1.0 to ensure floating-point division.
  • A suggestion is made to use double instead of float for increased precision in calculations.
  • One participant mentions that the assignment statement in the loop could be written as x += 1.0/factorial(i) for clarity.
  • A later reply highlights that truncation will occur at i >= 18 due to the limitations of floating-point representation, suggesting a reversal of the loop order and the use of 64-bit integers for factorial calculations.
Participants express multiple competing views regarding the best approach to avoid truncation, and the discussion remains unresolved as different methods and their implications are considered.
Limitations include the dependence on the choice of data types (float vs. double) and the potential for truncation due to the size of factorial values in relation to floating-point representation.
Superposed_Cat
Hi, just started c++ and I made this program to calculate the value of eulers number. It works in c# but truncates the decimal points as far as I can tell. What am I doing wrong?
Code:
#include <iostream>
using namespace std;
int factorial(int a){
    int b=1;
while(a>0){
    b=b*a;
    a--;
    return(b);
int main()
 float x=1.0;
 for(int i=1;i<25;i++){
     x=x+1/factorial(i);
   cout <<x;
   return 0;
Technology news on Phys.org
factorial is an integer function; cast it to float ...
The 1/factorial will do integer division. You need to use 1.0 to get floating pt division.
Thanks. Those must be the fastest responses I've ever had.
For more precision, use double instead of float.
Also, many programmers would write the assignment statement in the for loop as
Code:
x += 1.0/factorial(i);
You can do something similar in the code in your factorial function.
Your indentation could be tweaked a bit to make your code more readable. On the plus side you used code tags - good!
Here's how I would indent this code. I have also added more spaces
Code:
#include <iostream>
    int b = 1;
    while(a > 0){
       b *= a;
       a--;
   return(b);
int main()
   float x = 1.0;
   for(int i = 1; i < 25; i++){
   cout <<x;
   return 0;
noticed that after posting.(the += thing the double I completely forgot about, thanks)
Note that 25! is greater than 2^83. 18! is greater than 2^52, so truncation will occur at i >= 18 when adding 1/i! to a double >= 2.0. You could reverse the order of the loop (for i = 20; i >= 1; i--) and use 64 bit integers for factorial (20! < 2^62), but it wouldn't make much difference.
  • · Replies 22 ·
  • · Replies 40 ·
