How Does the Integrating Factor Simplify Differential Equations?
The discussion focuses on the use of integrating factors in solving differential equations, specifically addressing the confusion around the transformation of the equation after applying the integrating factor. The integrating factor is derived as I(x) = e^(∫p(x)), which simplifies the equation when multiplied through. In the provided example, after multiplying both sides by e^(x), the left-hand side can be expressed as the derivative of the product e^(x)*y. This shows that the left-hand side simplifies to d[e^(x)*y]/dx, demonstrating the equivalence of the expressions. Understanding this relationship clarifies how the integrating factor facilitates solving the differential equation.
nick.martinez
im in calculus 2 right now and we are doing differential equaitons right now. I am confused as to why when i find the integrating factor I(x)=e^(∫p(x) and when i multiply both sides i get
e^∫(p(x))[(dy/dx)+p(x)*y]=d(e^(p(x)dx)*y) how are they equal. i will give an example.
(dy/dx)+y=x*e^(x) the integrating factor is e^(∫dx)=e^(x) then i multiply both sides by
e^(x) which gives
e^(x)*[(dy/dx)+y]=e^(x)*[x*e^(x)]
which is equal to:
d[e^(x)*y]/dx=e^(x)*x; basically my question is how do you get here? how does e^(x)*dy/dx just disappear after i multiply the integrating factor to both sides?
please help with what happens after this step: e^(x)*[(dy/dx)+y]=e^(x)*[x*e^(x)]
Lets see... your example is: ##\renewcommand{\dyx}[1]{\frac{d #1}{dx}}##
$$\dyx{y}+y=xe^{x}$$ - integrating factor is: ##e^{\int dx}=e^x##
multiplying both sides by the integrating factor gives you:
$$e^x\left [ \dyx{y}+y \right ] = e^x\left [ xe^x \right ]$$ ... to from there to the end result - you must first multiply out the brackets.
But you can see that the two expressions are the same by doing the differentiation on the LHS:
$$\dyx{} [e^x y]$$
This is how you choose the integrating factor - you have to notice that this relation will work.
http://tutorial.math.lamar.edu/Classes/DE/Linear.aspx
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 19 ·
