Calculate Block Friction: 2-kg Block & Horizontal Spring
  • Thread starter Thread starter anastasiaw
7 replies · 6K views
anastasiaw
A 2- kg block rests against one end of a horizontal spring which is compressed by 18 cm. When the spring is released, the spring forces the block to slide across a table top. It stops 47 cm from where you released it. The spring constant k is equal to 120 N/m. Calculate the constant of kinetic friction μk between the block and the table.
W=.5kx^2
W=Fd
I used the two equation above to find that F=4.136N
Somebody suggested I should put this into the equation F=μk*F(n), but I don't know how to find F(n). Any help?
The table is horizontal. Consider the vertical forces acting on the block.
Okay, gravity? How do I apply that to this problem?
Gravity is one of the forces on the block.
Answer this: A block sits on the table. What normal force must the table exert on the block?
Okay I got it -- F(n) is the normal force... the weight of the object. Thanks.
Consider the work done by frictional force. It will be equal to?
μk x Normal Force = ?
That's the friction force. How do you find work?
