Calculate Coulombs Law: Charge, Current, and Power in Electrical Circuits
A charge of 4000μC is equivalent to 0.004 coulombs, calculated by converting microcoulombs to coulombs. The current in the wire is determined using the formula current = charge/time, resulting in 0.08 A. To find the number of electrons passing each point in the wire, the charge is divided by the electron charge (1.6 x 10^-19 C), yielding approximately 2.5 x 10^16 electrons per second. For the kettle, the current is calculated from the energy transferred (6.9 x 10^5 joules) over 5 minutes, resulting in a current of 23 A. The power of the electric bar fire, with a resistance of 50 ohms and connected to a 240V supply, can be calculated using the formula power = voltage^2/resistance, resulting in 1152 watts.
ydna7
Q1. A charge of 4000μC passes each point in a wire in 50s
Calculate: a) the charge in coulombs
b) The current in the wire
c) The number of electrons per second passing each point in the wire (Electron charge = 1.6 * 10^-19 C)
Q.2 A 240V kettle transfers 6.9*10^5 joules of energy in 5 minutes. What is the current in the kettle?
Q.3 When hot an electric bar fire has resistance of 50ohms. When connected to the mains supply (240V) what is its power?
Really struggling with this..
I'm sure you can find these in your book:
current=charge/time
charge=(#electrons)(electron charge)
power=(current)(voltage)
power=work/time
current=charge/time
power=work/time
I have been away a lot lately and have fallen behind a bit..
so a) = 4000/50=80 coulombs?
b) (#electorons=?)(4000)=??
c)
a) doesn't make sense. Charge where? Is this part of a bigger question?
It looks like (a) is trivial: 1 uC is 10^-6C
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
