Is 8.3 or 11.7 the Correct Equilibrium Constant?
The equilibrium constant (Kc) for the reaction 2A + B ⇌ C was calculated using the equilibrium concentrations, resulting in a value of 8.3. However, a textbook indicates the correct answer as 11.7, leading to confusion. The initial concentrations provided are deemed unnecessary since they align with the final concentrations. The calculations confirm that the answer of 8.3 is correct based on the equilibrium state. Clarification is sought on why the textbook lists a different value.
Aafia
[/B]
The following reaction was allowed to reach the state of equilibrium
2A+B <====> C
The initial amounts of reactant present in one litre of solution were 0.5 mole of A and 0.6 mole of B. At equilibrium the amounts were 0.2 mole of A and 0.45 mole of B and 0.15 mole of C. Calculate equilibrium constant
Kc= [product]/[reactants]
[/B]
Kc= [0.15]/0.2^2×0.45
Kc=0.15/0.018
= 8.3
In my book one of the option of mcq given is 8.3 but the option marked as correct is 11.7 which one is right? If 11.7 is correct then how?
Aafia said:
[/B]
2A+B <====> C
[/B]
Kc=0.15/0.018
= 8.3
I do not see any reason your answer be wrong.
The question contains the superfluous information of initial concentrations, but as you can check these are consistent with the final.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
  • · Replies 19 ·
