Calculate final velocity of electric particle
The discussion centers on calculating the final velocity of an electric particle with a mass of 7.3 × 10-5 g and a charge of 24 mC in a uniform electric field of 6.3 N/C. The initial velocity is given as vy = 4.1 × 105 m/s, with vx and vz equal to zero. The correct final speed after 0.4 seconds is determined by calculating the acceleration using F = qE and applying the kinematic equation v = vi + at. The final answer, calculated as 1238493.151 m/s, is confirmed to be correct when considering both velocity components.
  • Understanding of Newton's second law (F = ma)
  • Knowledge of electric force (F = qE)
  • Familiarity with kinematic equations (v = vi + at)
  • Basic vector addition for calculating resultant velocity
  • Study the principles of electric fields and forces in physics
  • Learn about kinematic equations and their applications in two dimensions
  • Explore vector addition techniques for calculating resultant velocities
  • Investigate the significance of significant figures in scientific calculations
Students in physics, particularly those studying electromagnetism and kinematics, as well as educators seeking to clarify concepts related to electric forces and particle motion.
beeteep
A particle of mass 7.3 × 10−5 g and charge 24 mC moves in a region of space where the electric field is uniform and is 6.3 N/C in the x direction and zero in the y and z direction. If the initial velocity of the particle is given by vy = 4.1 × 105 m/s, vx = vz = 0, what is the speed of the particle at 0.4 s? Answer in units of m/s
F=ma
F=qE
v=vi + at
m=7.3x10-8 kg
q=.024 C
E=6.3 N/C
F = .024(6.3) = .1512 N
.1512 = 7.3x10-8a
a = 2071232.877 m/s2x = doesn't matter
xi = doesn't matter
v = ?
vi = 4.1x10^5
a = 2071232.877
t = .4
v = vi + at
v = 4.1x105 + 2071232.877(.4) = 1238493.151 m/s
Final Answer = 1238493.151
But the system says it's wrong...
Any help is appreciated! Thanks!
Ten significant figures?
The system is supposed to count your answer correct if you're within +/- 1% of the correct answer, so I err on the side of caution and put in every digit I have since it did not specify how many significant figures it wanted.
beeteep said:
charge 24 mC
Isn't that rather large? Should it be μC?
beeteep said:
v = vi + at
Yes, but not vxi+ayt.
Correction, I meant:
Yes, but not vyi+axt.
Most of the problems I have worked have been μC but I just double checked and this problem definitely says mC.
OK, but please see the edit to my previous post.
OK. I think I see what you're saying. According to the problem statement, since the vyi is given and there is no force acting in the y-direction, vyf=vyi. Then I'd calculate the vxf with vxi=0 and include the acceleration for .4s which would give me two components to a vector, right? With that, I could take the square-root of (vx2 + vy2) and that would give me the speed?
Yes.
Some heroes don't wear capes. :smile:
Thank you so much for your help!
  • · Replies 49 ·
