Calculate Flux & Current at Intersection of Neutron Beams
  • Thread starter Thread starter timman_24
    Current Flux
The discussion focuses on calculating the flux and current at the intersection of two monoenergetic neutron beams, I1=2*10^10 and I2=1*10^10, intersecting at a 30-degree angle. The flux is determined using the formula I1 + I2*cos(30), resulting in a value of 2.866*10^10 n/(cm^2-s). The current is represented as a vector J(Jx, Jy), where Jx is calculated as I1 + I2*cos(30) and Jy as I2*sin(30), yielding J(2.866*10^10 i + 0.5*10^10 j). The user expresses uncertainty regarding the distinction between flux and current, indicating a common area of confusion in the topic.
  • Understanding of neutron beam intensity and its measurement
  • Familiarity with vector representation in physics
  • Knowledge of trigonometric functions and their application in physics
  • Basic concepts of flux and current in particle physics
  • Study the principles of neutron beam interactions in physics
  • Learn about vector calculus in the context of physics
  • Explore the differences between flux and current in electromagnetic theory
  • Investigate practical applications of neutron beams in scientific research
Students and professionals in physics, particularly those focusing on particle physics, neutron interactions, and vector analysis in scientific calculations.
timman_24
Two monoenergetic neutron beams I1=2*10^10 and I2=1*10^10 intersect at an angle of 30 degrees. Calculate both the flux and current in the region where they intersect.
I lined the first I1 up parallel to the x-axis and tilted I2 30 degrees below I1 to make the calculations easier.
Flux:
I believe flux is the amount of neutrons passing between the left side to the right side across this arbitrary surface area. I took the surface area to span the y-z axis with the flux passing along the x-axis.
To calculate the flux, I simple did:
I1 + I2*cos(30) = 2.866*10^10 n/(cm^2-s)
Current:
I believe the current to be the vector representation of the net flow. For this I did the following:
J(Jx,Jy) = Jx + Jy
Jx= I1 + I2*cos(30)
Jy= I2*sin(30)
J(Jx,Jy) = 2.866*10^10 i +.5*10^10 j
I am not 100% positive if this is the correct way to do this. I get confused sometimes between current and flux.
Any help would be much appreciated!
I guess a lot of people have trouble with flux and current? :-p
