How Do I Calculate Maximum Torque for a Structural Aluminium Pipe?
  • Thread starter Thread starter febbie22
    Maximum Torque
To calculate the maximum torque for a 2.4 m structural aluminium pipe (6063-T6), it is essential to consider the maximum allowable shear stress, which is 0.4 times the yield stress, and the maximum angle of twist of 15 degrees. The calculations involve using the torque equation T/J = τ/r and T = (Gθ/L)J, ensuring all values align for consistency. Initial calculations yielded different torque values, indicating a potential misunderstanding of the allowable stress. The correct approach requires using the maximum allowable shear stress rather than the yield stress directly. Accurate torque calculation is crucial for ensuring structural integrity in design.
febbie22
A 2.4 m long structural aluminium pipe (series 6063-T6) is used as part of a roof structure. As part of the design process it is required to assess the suitability of different sizes of pipe.
Calculate the maximum torque that can be applied to the shaft if the maximum allowable yield stress and angle of twist are to be complied with.
Outside Diameter = 33.40mm Wall Thickness = 3.38mm Nominal Size = 25.40
Shear Modulus = 27GPA Max Allowed Angle 15 degrees Max Allowed Stress 68800000
Just wondering i need to calculate the Torque and i know the torque equation but do i just choose two out of the 3 sections ie T/J = Stress/r or do i need to use all three, as it says in the question the max stress and max angle which are in the other two sections of the equations.
when i use two i get 174.85NM which i thought was kind of low
Cheers
Well obviously the values of the three sections should all equal each other, i.e T/J = τ/r = Gθ/L = C otherwise one of your values is wrong. If you know the angle, the length of the specimen and its shear modulus then T = JGθ/L.
This is what i have done but the answer is still not the same
Od = 0.03340m
Id = 0.02664m
Shear modulus = 27GPa
yield stress = 172Mpa
Max allowable shear stress = 0.4 * yield stress
Max Angle 15 degrees
lentgh = 2.4m
T = (Stress/r)*J
(172MPa * 0.4 /0.0167)* (Pie/32*(0.03340^4-0.02664^4)
= 299.63 Nm
The other way using
T= ((G*angle)/L)*J
27GPa*(15*(Pie/180))/ 2.4 * 7.27x10^-8
= 214.12N,
whats going wrong i don't get it
The maximum allowable stress is 0.4 x the yield strength. You're using the yield stress in your calculation rather than the maximum allowable stress.
but it says in the handout that i got that the maximum allowabale shear stress is equal to
0.4 * the yield stress
ive included the handout in an attachment
thanks for the help by the way, but how do i find the shear stress then.
cheers
Yes, which is what I said.
τ = r(T/J) = r(Gθ/L)
cheers
It appears we go to the same university.
hey, thanks for replying
so do i even need to bother with the 0.4 x the yield
when i can just use the formula you gave to find the stress
Obviously you need to bother with the 0.4*yield because that's the maximum allowable stress.
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 20 ·
10K
