Calculate Phase Voltage On Unbalanced Load if Neutral Disconnected
The discussion revolves around calculating the phase voltage on an unbalanced three-phase star-connected load when the neutral wire is disconnected. Participants explore methods for determining the neutral current and the voltage between the star point and the neutral wire, focusing on nodal analysis and related calculations.
  • Homework-related
  • One participant confidently calculated the neutral current using the given line and phase voltages and impedances.
  • Another participant suggested drawing a schematic without the neutral wire and using nodal analysis to find the potential of the relevant node.
  • Some participants expressed confusion about the reference node and requested demonstrations of the solution process.
  • One participant proposed a formula for calculating the voltage between the star point and neutral wire, derived from a similar problem found in a library book, but expressed doubt about its correctness due to the result being close to the supply phase voltage.
  • Another participant confirmed the formula's correctness but advised rechecking certain values and suggested that the final result should be less than 100V.
  • Participants discussed the importance of understanding nodal analysis and its application in electrical systems.
Participants generally agree on the approach of using nodal analysis but have differing levels of confidence in their understanding and application of the method. There is no consensus on the correctness of the proposed calculations, and some participants express uncertainty about specific steps.
Participants noted potential issues with the accuracy of values used in calculations and the need for clarity in deriving formulas. The discussion reflects varying levels of familiarity with nodal analysis and its application in solving the problem.
This discussion may be useful for students and practitioners in electrical engineering, particularly those interested in three-phase systems, unbalanced loads, and nodal analysis techniques.
blueboxcat
An Unbalanced 3-phase star connected load has the details as below.
Line Voltage=400V
Voltage R-N = 230V 0°
Voltage B-N = 230V +120°
Voltage W-N= 230V -120°
Impedance R-N = 100+J36
Impedance B-N = 102+J0
Impedance W-N = 50+J0
A.) Determine the neutral current(im confident in this)
B.) Determine the voltage between the star point and neutral wire if the neutral wire(Vn-o) becomes disconnected. (Im not sure how to do this)
I calculated neutral current.
converted all impedances to polar to calculate current
Ir=Vph/Zr=230V 0° / 106.28ohm 19.8° = 2.1641A -19.8°
Ib=230V 120° / 102ohm 0° = 2.25A 120°
Ic=230V 240° / 50ohm 240° = 4.6A 240°
Converted these to Rectangular hen Added them together to determine neutral current
Ir=2.16A -19.8°=2.0361-J0.733
Ib=2.25A 120° =-1.125+J1.95
Iy=4.60A 240° =-2.3-J3.98
(2.0361-J0.733)+(-1.125+J1.95)+(-2.3-J3.98) = -1.3889-J2.7631 = 3.09A -116.69°
Now i do not know how to approach question b.) Determine the voltage between the star point and neutral wire if the neutral wire(Vn-o) becomes disconnected.
Draw the schematic without the neutral wire. If you take the junction of the voltage sources as the reference node (Neutral), there's one other node and it happens to be the one you're interested in. Write the nodal equation and solve for the potential of that node.
Im having trouble understanding your explanation, if i make the star point the reference node, where is this other node? are you able to demonstrate to me how to solve it?
Sorry, we can't provide solutions to homework, only help, hints, clarifications, etc.
You have star-connected sources and star-connected loads. In the 4-wire system the Neutral wire joins the node where the sources come together to the node where the loads come together. Here you are asked to remove that Neutral wire and determine the potential difference between these now separate nodes. Looks like an ideal case for nodal analysis.
Here's your circuit with the neutral wire still in place:
Hey, I am not confident in node voltage analysis as I am only in my first month of power engineering. Though i do intend to look into it. I found a similar problem in a book at the library and found the solution, are you able to confirm if this is correct or not?
Vn-o= ((Vr x Yr)+(Vy x Yy)+(Vb x Yb)) / (Yr + Yy + Yb)
Yr = 1/100+j36 = 1/106.28 , 19.8° = 9.41 , -19.8°
Yb = 1/102+J0 = 1/102, 0° = 0.009804 , 0°
Yw = 1/50+ J0 = 1/50 , 0° = 0.02 , 0°
Vn-o = ((230 , 0° x 9.41 , -19.8) + (230 , -120° x 0.02) + (230 , 120° x 0.009804 , 0°)) / ((8.85-J3.19)+(0.009804) + (.02)
Vn-o = (2161.7652 , -19.88°) / (9.4356 , -19.76)
Vn-o = 229.11V -12°
Im doubting whether my answer is correct because it is incredibly close to the supply phase voltage(230v) . But I am thinking this could also be a coincidence. Are you able to tell me if I am wrong and if so, where i have went wrong? Thank you
The above formula is correct. Do you understand where it comes from (how to derive it)? You won't have the library at your disposal at exam time...
Recheck the value I've indicated in red; Looks waaay too big.
Vn-o = 229.11V -12°
Fix the value I've indicated and redo your math. The result should be less than 100V.
I'd suggest looking up and reviewing the nodal analysis technique. It's usefulness will come up again and again in electrical systems.
