Calculate Sugar Density: 1590kg/m^3 to g/cm^3
  • Thread starter Thread starter Chemistry101
    Chemistry
The discussion revolves around converting the density of sugar from kilograms per cubic meter (kg/m³) to grams per cubic centimeter (g/cm³). Participants explore the necessary calculations and unit conversions involved in this process.
  • Homework-related
  • One participant asks for help in converting the density of sugar from kg/m³ to g/cm³, noting the conversion factor for volume.
  • Another participant suggests that the problem can be solved using a simple proportion.
  • A participant questions whether the given data is already in cm³.
  • One participant expresses confusion about the proportion needed for the conversion.
  • Another participant provides a formula involving unit conversions but does not clarify the steps.
  • There is a correction regarding the conversion factor for cubic meters to cubic centimeters, with one participant stating that 1 m³ equals 1,000,000 cm³.
  • A later reply calculates the final answer as 1.59 g/cm³ based on the conversions discussed.
Participants generally agree on the method of conversion but express confusion over specific steps and the correct application of unit factors. The discussion includes multiple perspectives on how to approach the problem, indicating that no single method is universally accepted.
Some participants express uncertainty about the correct conversion factors and the proportional relationships between the units involved. There are also corrections made regarding the interpretation of volume units.
This discussion may be useful for students or individuals seeking to understand unit conversions in density calculations, particularly in the context of chemistry or physics.
Chemistry101
What is the density of sugar g/cm^3 if its density is 1590kg/m^3?
Hint: 1m^3 equals 1,000,000cm^3.
I know that 1590kg to g is 1,590,000g.
But how do I get the other half of it to cm^3?
Help.
Thanks.
Your question is just a simple proportion problem. You have the needed ratio; just use it.
Isnt it already in cm^3 in your given data
Sorry I can't see the proportion.
What is it?
EDIT: I meant m^3.
1590kg/cm^3 times 1000g/1kg times 100cm/1m
your units should cancel out to give you the answer...and on the last part it should be 100cm^3/1 m^3
The question is asking to convert from kg/m^3 to g/cm^3.
oh ok my bad...then it would be 1590kg/m^3 times 1000g/1kg times 1m^3/100 cm^3
but 1 m^3 = 1,000,000 cm^3
put that 1,000,000 cm^3 in place of my 100cm^3
my bad sorry for the confussion
its ok thanks.
The answer will be 1590*1000/1000000 = 1.59g/cm^3.
