Calculate the angular velocity and angular acceleration (pendulum)
1 reply · 6K views · last reply
Alexanddros81
13.53 The tension in the sting of the simple pendulum is 7.5N when θ=30deg.
Calculate the angular velocity and angular acceleration of the string at this instant.
Diagram of a simple pendulum hanging from pivot O with string length 2 m, angle θ measured from the vertical dashed line through A, and a 0.5 kg bob on a curved arc below. Caption: Fig. P13.53, P13.54.
Handwritten solution to a pendulum problem: a sketch of a pendulum bob on a string from pivot O at angle theta, tension T and weight mg labelled, with radial and tangential accelerations marked. Below are force equations, with the result theta-dot squared = 3.23 and theta-dot = 1.8 rad/s, and theta-double-dot = -2.45 rad/s squared.
Is this correct?
