Calculate the Average Surface Temperature of Earth
The average surface temperature of Earth can be estimated using the Stefan-Boltzmann law, represented by the equation P = eσAT^4. Given that the Earth receives approximately 390 W/m² of radiant energy from the Sun, the calculated average surface temperature is 288 Kelvin (15°C) when considering a surface area of 1 m². However, accounting for Earth's albedo of 30% reduces the effective power to about 340 W/m², resulting in a more accurate average temperature of 255 Kelvin.
  • Understanding of the Stefan-Boltzmann law
  • Knowledge of radiant energy and thermal equilibrium
  • Familiarity with the concept of albedo
  • Basic proficiency in algebra for manipulating equations
  • Research the Stefan-Boltzmann constant and its applications in thermodynamics
  • Learn about the effects of albedo on planetary temperatures
  • Explore the concept of thermal equilibrium in planetary science
  • Investigate the implications of solar radiation on climate models
Students studying physics, climate scientists, and anyone interested in understanding Earth's energy balance and temperature calculations.
lasisdabomb
The Earth receives on average about 390 W m−2 of radiant thermal energy from the Sun, averaged over the whole of the Earth. It radiates an equal amount back into space, maintaining a thermal equilibrium that keeps the average temperature on Earth the same. Assuming the Earth is a perfect emitter of radiant energy (e = 1), estimate the average surface temperature of the Earth in °C
P = eσAT^4
P ∝ T^4
λmaxT = 2.898 × 10−3 m K
3. Attempt
I've tried all these formulas, but I'm not getting anywhere. Am I supposed to know the surface area of the Earth because I feel like it's impossible without it
Assume the area of the Earth to be ##A##, a variable. What, then, is the total power incident on the Earth's surface?
Is the 390 m^-2 relevant for the equation. Should that be stated as the P value or should it just be 390W
Do you know what intensity is? It's formula? It's unit?
I've realized how to do it. The Power is average for each m^2 of earth. That means the surface area should be 1m^2 and the Power should be 390.
By subbing everything in, you get an average surface temperature of 288 Kelvin or 15°C
More appropriate wording would be - an average of 390W of power is incident per sq.m on the surface of the earth. This is what you mean, right?
And congratulations, on having solved the problem:smile:
Yes, that's the right answer with the given information, but 390 W/m2 is too high. Should be more like 340.
Taking the 30% albedo into account as well would bring the temperature down to 255K, which is the standard result.
Thanks for the info!
  • · Replies 42 ·
9K
  • · Replies 21 ·
14K
9K
