Calculate the charge of a density distributed along z axis?
The problem involves calculating the total charge from a material with a specified volume charge density, given by ρ = 10-9 cos(z/z0) C/m3, distributed along the z-axis between specific limits. Participants are exploring the implications of the charge density and its distribution.
  • Exploratory, Assumption checking
  • One participant suggests treating the charge density as a volume charge density with cylindrical symmetry, while noting the lack of information about the radius. Another participant proposes that the charge density may represent a line charge, leading to the use of a Dirac delta function for resolution. Questions arise regarding which approach is correct or if neither is valid.
Participants are actively discussing the assumptions regarding the charge distribution and the implications of missing information. Some suggest that the problem may lack necessary details, while others are considering alternative interpretations of the charge density. There is no explicit consensus on the correct approach, but guidance is being offered regarding the need for additional context.
Participants note that the problem does not specify the radius for a cylindrical distribution, leading to questions about the nature of the charge distribution. The lack of explicit information about the material's geometry is acknowledged as a potential issue in solving the problem.
flux!
How do I find the total charge from a material with a charge density given by
\rho =10^{-9} \text{cos}\left ( \frac{z}{z_0}\right ) C/m^3
that exist between \frac{-\pi}{3}z_0<z<\frac{\pi}{3}z_0.
None I can think of.
Attempt #1:
Since the charge density is a volume charge density we may assume that we are dealing with a cylindrical charge distribution that remains the same along r. However, the radius of the assumed shaped was not given, so let us assume that its radius is r_0. We may solve this by:
q=\int_V \rho d\tau q=\int_0^{r_0} \int_0^{2\pi} \int_{\frac{-\pi}{3}z_0}^{\frac{\pi}{3}z_0} 10^{-9} \text{cos}\left ( \frac{z}{z_0}\right ) C/m^3 rdrd\phi dz
Everything will then be straight forward, but the issue is that
1. r_0 is not given, and
2. the problem did not say it is a cylindrical charge density.
This is just, however, one way I could deal with a volume charge density that does not have a given volume, unusual huh.
Attempt #2:
Since the problem indicated that the volume charge density is distributed on a line, then it must be a line charge only. Thus it must have an infinitesimal radius that could be resolve by Dirac Delta function, so:
must be equivalent to:
\rho =\delta(r,\phi - r',\phi')10^{-9} \text{cos}\left ( \frac{z}{z_0}\right ) C/m
then, things could now be easily solved in the integral:
q=\int_V \left (\delta(r,\phi - r',\phi')10^{-9} \text{cos}\left ( \frac{z}{z_0}\right ) C/m\right )d\tau
4. My Question
Now, my question is, which two approaches is the right solution, Or if neither any of the two is correct, how should we solve the total charge of a density given above?
Cross-Link: Posted the Question In physics.exchange but, does not seem to get answered, Hope you guys help me out. http://physics.stackexchange.com/questions/240215/how-to-compute-the-charge-of-a-density-distributed-along-z-axis
You are specifically given units of C/m3 ... so this is explicitly a volume charge density.
The only dpendence given is z, so a cylindrical symmetry is reasonable.
The question appears to call for the total charge between two planes so ##r\in [0,\infty)## ... but that gives you an infinite charge.
It follows that there is some information missing from the problem statement, or the statement is in error.
You need to use the context that the question is set into further determine the limits for the volume.
Hi, that what all the problem given. No r for a cylinder or so. The problem just tells that the charge is distributed on z.
That's why I suggest going to the context - sometimes the needed information is not explicitly given.
Maybe the "material" is finite in a way mentioned elsewhere?
There are too many other possibilities to safely guess ... which is basically what you are doing above.
Have you asked the other students to see how they are handling it?
If you cannot ask anyone, and you must turn in something, then you will have to just leave ##r_0## as a variable.
I see no need to assume it is a cylinder. Just assume the cross-sectional area in the XY plane is constant, A.
However, this still leaves such a trivial problem that I suspect the missing information is crucial.
Thanks for the responses! I will just assume that there might be a missing information. In case there is none, is my solution involving dirac-delta correct?
  • · Replies 19 ·
