Calculate the conductivity σ of the material of which this wire is made
To calculate the conductivity σ of the wire, the resistance R can be determined using the formula R = V/I, where V is the potential difference (2.1 V) and I is the current (5.4 A), resulting in R = 0.3889 ohms. The resistivity ρ can be calculated using the formula ρ = R(A/L), where A is the cross-sectional area (1.1 mm² or 1.1 x 10^-6 m²) and L is the length (1.0 m). Substituting the values gives ρ = 0.3889 ohms * (1.1 x 10^-6 m² / 1.0 m), resulting in a resistivity of approximately 4.28 x 10^-7 ohm-m. The conductivity σ is then found using the relationship σ = 1/ρ, leading to a conductivity of about 2.34 x 10^6 S/m. This calculation highlights the relationship between resistance, resistivity, and conductivity in electrical materials.
mh53eflyguy
A wire is 1.0 m long and 1.1 mm2 in cross-sectional area. It carries a current of 5.4 A when a 2.1 V potential difference is applied between its ends. Calculate the conductivity σ of the material of which this wire is made.
Known data: I hate Wileyplus.
Ok, REAL known data: I know that I have to use 2pi(r), and pi(r)^2
R= (roe)(L)/(A)
I understand that if I were to use a specific material, I could find the resistance. However, this does not ask for that. Please help!
Welcome to PF.
You know the resistance from V/I.
You know the A.
You know the Length.
So what is σ?
σ = 1/ρ
and
R = ρL/A
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
