Calculate the current in the coil
  • Thread starter Thread starter mba444
    Coil Current
The discussion focuses on calculating the current in a circular coil with 394 turns and an area of 0.78 m² placed in a magnetic field of 0.8 T, resulting in a maximum torque of 0.0059 N·m. The correct formula for current is derived as i = torque / (number of turns * area * magnetic field). The participants clarify that the total length of the wire must be calculated to determine the new area for a single-turn larger coil, leading to a final area of 121084 m² and the correct current calculation.
  • Understanding of torque in magnetic fields
  • Familiarity with the formula torque = i * A * B
  • Knowledge of geometry for calculating the area and circumference of a circle
  • Basic algebra for solving equations
  • Learn about magnetic torque and its applications in electromagnetism
  • Study the relationship between turns, area, and magnetic field in coil design
  • Explore the geometry of circles to enhance understanding of coil dimensions
  • Investigate practical applications of coils in electric motors and generators
Students studying electromagnetism, physics educators, and engineers involved in coil design and analysis.
mba444
A circular coil of 394 turns and area 0.78 m2
is in a uniform magnetic field of 0.8 T. The
maximum torque exerted on the coil by the
field is 0.0059 N · m.
Calculate the current in the coil. Answer in
units of A
torque= i*A*B
what i did is that i solved for the current using the above equation i= torque/(A*B) but i keep getting the wrong answer .. i think because of the number of turns but i don't know were to include it
i need ur help thanks in advance
Torque = μ X B, where μ = nIA.
so is it
i = torque /(number of turns *A*B)
mba444 said:
so is it
Yes.
Assume the 394 turns of wire are used to form
a single-turn coil with the same shape but
much larger area.
What is the current if the maximum torque
exerted on the coil by the field is 0.0059 N · m?
this a second part of the question but i really didnt understand the difference
You need to figure out the area of this larger coil. Hint: What's the length of the wire?
i tried to figure out the length where i came up with this equation but still i couldn't figure what to put for the F
length = F/(i*B)
im kind of lost
Figuring out the length of the wire is a geometry problem. You had a coil of a given area and number of turns. What was the circumference of that coil?
C= 2*pi*r
mba444 said:
C= 2*pi*r
Good. Use the known area to find the radius.
ok i did so know
1 loop = 2*pi*r (i just found)
394= X
so do i do the cross multiplication to solve for X which is the new area
mba444 said:
ok i did so know
394= X
Do this:
Use the area of the original coil to solve for the radius, using A = pi*r².
Use the radius to find the length of each loop, using the circumference formula.
Find the total length of the wire by multiplying the length of each loop by the number of loops.
That becomes your new circumference of your big coil. Work backwards to find, its radius then area.
ok thanks a lot i got it know .. sorry if i wasted your time
i got for the larger area = 121084 m^2
i plugged in this eqs i = (.0059)/(394*121084*0.8)
but i got the wrong answer =(
That looks OK.
When used to make the giant coil there's only one turn.
thanx again i got the right answer
