Calculate the force of an explosion from chemical reaction?
The calculation of explosion force from a chemical reaction, specifically the combustion of hydrogen and oxygen, is complex and highly dependent on various factors including the energy release and the physical characteristics of the impacted object. A mixture of 5 grams of oxygen and 10 grams of hydrogen, when ignited, releases approximately 120 MJ/kg of energy. The molecular weight ratio must be approximately eight to one in favor of oxygen to achieve optimal combustion. Maximum overpressure is a common metric used, but energy release is more frequently referenced in these calculations.
  • Understanding of chemical reactions and combustion principles
  • Knowledge of molecular weights and mass ratios in chemical mixtures
  • Familiarity with energy release metrics, specifically heat of combustion
  • Basic physics concepts related to force and pressure
  • Research the concept of maximum overpressure in explosive reactions
  • Study the heat of combustion for various fuels, focusing on hydrogen
  • Explore the relationship between energy release and force in explosive events
  • Investigate the impact of distance and object characteristics on explosion force
Chemists, physicists, engineers, and safety professionals involved in explosive materials and energy release calculations will benefit from this discussion.
yrjosmiel73
Example, I have a mixture of 5 grams of oxygen and 10 grams of hydrogen. I ignite them. How much force will the explosion do?
Yes, I did think about posting this in the chem category but this is about forces, right?
Sorry, but that's an extremely complicated, but largely meaningless question. It depends on both the explosion and the distance, shape, strength and mass of the object being impacted, and even then is a pretty weak description.
Now, sometimes maximum over pressure is used, but more common is energy.
Note that the molecular weights of hydrogen and oxygen are very different. You would need mass ratio of approximately eight to one in favor of oxygen to achieve a number-of-atoms ratio of two to one in favor of hydrogen.
I assume that you are trying to specify a perfect mix here.
https://en.wikipedia.org/wiki/Heat_of_combustion#Heat_of_combustion_tables
When you burn hydrogen it will release 120 MJ/kg (The lower heating value means that you do not take into account the condensation of the water vapor in combustion). Pressure and force depend on how this energy is released and are very case-dependent.
  • · Replies 46 ·
  • · Replies 35 ·
