Calculate the mass of the disk?
  • Thread starter Thread starter alaa amed
    Disk Mass
The discussion revolves around calculating the mass of a disk given the moment of inertia of a disk-clay system. The moment of inertia is provided as I = 1.5 kg m², with the clay's mass known to be 0.12 kg. Participants emphasize the need to correctly interpret the axis of rotation and the distances from the axis to the mass elements, as the radius for both the disk and clay is not specified. The moment of inertia for a disk is noted as I = 1/4 MR², but the moment of inertia for the clay needs clarification. A complete understanding requires a diagram and the full problem statement to avoid assumptions.
alaa amed
The moment of inertia of the disk-clay system about the central axis of the disk is I = 1.5 kg m2
Disk's mass = M
The clay's mass = 0.12 kg
I = m r^2
I thought that the moment of inertia may just be the sum of the individual moment of inertia's of the two objects. I know that I for a disk is equal to 1/4 MR^2, but I do not know the one for the clay.[/B]
Correct.
You sure you've interpreted the axis correctly?
https://en.wikipedia.org/wiki/List_of_moments_of_inertia
Was there a diagram? As it is, we don't know r disk or rclay so can't find mclay.
billy_joule said:
Correct.
Yes. The diagram showed a piece of clay is sitting at the rim of the disk and not sliding on the disk.
Post the diagram and the entire question statement word for word, without it we're just guessing/relying on your interpretation.
A horizontal uniform disk with a mass M and a radius R=1.5m is free to rotate about its central axis perpendicular to the disk’s flat surface. A piece of clay with a mass m=0.12kg is sitting at the rim of the disk and does not slide on the disk. The moment of inertia of the disk-clay system about the central axis of the disk is I=1.5kgm2.At time t=0s, a constant external force, F, is applied tangentially at the rim of the disk causing the disk-clay system, initially at rest, to start rotating with a constant angular acceleration ofα=0.25rad/s2.
There's doesn't appear to be a question?
Can you follow the link in post #2 and identify the relevant MOI equations for the disk and clay?
Note that part of the axis specification.
  • · Replies 19 ·
  • · Replies 28 ·
  • · Replies 25 ·
11K
