- 29,512
- 21,283
Okay, the answer is one of those, but not a).ALIAHMAD said:this
this question has option sgiven as follows
a-20√3N
b-50√3N
c-50N
d-20√5 N
The discussion revolves around calculating the minimum force required to move a block, considering the angle of applied force and friction. The subject area includes dynamics and forces, particularly focusing on the interaction between applied forces and frictional forces.
The discussion is ongoing, with various participants providing insights and questioning assumptions about the angle of force application. Some guidance has been offered regarding the setup of equations and the importance of considering the angle above the horizontal. There is recognition of the need for further analysis to determine the minimum force required.
Participants mention that the problem is from a coaching institute's practice paper for JEE preparation, indicating a level of complexity that may not require advanced calculus. There is also mention of specific answer choices provided for the problem, which may influence the direction of the discussion.
a-20√3N
b-50√3N
c-50N
d-20√5 N
You need calculus to get that answer. It's a minimization problem. That generally means calculus is required.ALIAHMAD said:THE ANSWER GIVEN IS 20√5 maybe by considering that it is close to 25 as it was asked to be minimum
I understand your point but that's how the question is givenPeroK said:You need calculus to get that answer. It's a minimization problem. That generally means calculus is required.
But not always, and not here.PeroK said:Generally, you need calculus to minimise something in a problem with a continuous variable.
yeah I can do theseharuspex said:But not always, and not here.
@ALIAHMAD , if you write the two force balance equations and eliminate the normal force you should end up with ##F(\cos(\theta)+\mu\sin(\theta))=\mu W##.
The trick then is to multiply by a constant such that the trig terms can be collapsed into one: ##F(A\cos(\theta)+A\mu\sin(\theta))=A\mu W## where ##A=\sin(\alpha), A\mu=\cos(\alpha)##. Can you see how to choose A such that ##\alpha## exists? Can you then collapse that into a single trig term, and then spot what value of ##\theta## minimises F?
Or, by deriving that formula.ALIAHMAD said:yeah I can do these
like the combined trig term is sin(θ+𝜶)
my teacher told me that considering θ will make the question more complicated as for every angle there is some minimum and then to find the minimalist of them is very hard
he told me that these types of questions are solved by using this formula
F(min)=mgμ/√(1+μ^2)
Good, so what is the equation you get for F and what is A in terms of ##\mu##?ALIAHMAD said:the combined trig term is sin(θ+𝜶)
F=Cos𝜶W/[sin(θ+𝜶)] and A= cos𝜶/μharuspex said:Good, so what is the equation you get for F and what is A in terms of ##\mu##?
I meant, find A purely in terms of ##\mu##. ##\alpha## should not appear. But forget that, and instead find ##\alpha## purely in terms of ##\mu##.ALIAHMAD said:F=Cos𝜶W/[sin(θ+𝜶)] and A= cos𝜶/μ
It seems you have not really gotten the point here. The point is to introduce a constant ##A##, expressed only in the variable ##\mu##, that allows you to rewrite your expression using a single trigonometric function with ##\theta+\alpha## as its argument.ALIAHMAD said:F=Cos𝜶W/[sin(θ+𝜶)] and A= cos𝜶/μ
just wanted to know how that formula is derived as I don't see any clue on it
Here's a simpler alternative. To minimise ##F## we need to maximise ##\cos(\theta)+\mu\sin(\theta)##. That's easy once you know some calculus.haruspex said:But not always, and not here.
Sure, but the point of my post was, in view of post #28, to show it can be done without any calculus. Besides, it is a useful trick in another context: solving equations involving a mix of trig functions of the same unknown.PeroK said:That's easy once you know some calculus.
I get that, but a little differentiation goes a long way!haruspex said:Sure, but the point of my post was, in view of post #28, to show it can be done without any calculus. Besides, it is a useful trick in another context: solving equations involving a mix of trig functions of the same unknown.
This is incorrect.Spector989 said:So Force appliead is equal to friction applied
That’s fine but — again as already discussed in the thread — differentiation is not necessary in this problem.Spector989 said:You will face some differentiation and integration while solving PYQ , and especially whlie solving advanced questions so it is better to know some basic stuff , when to use it and when to use which (diff or integration) and how to use it.
Mb i should have mentioned it is equal to the horizontal component and Normal is equal to mg - minus vertical component (given force is applied above horizontal) and i simply siad that so that he wouldn't back off from differentiation and integration too much , in jee 11th you will face some calculus problems while solving some physics questions. But again it is my fault because i was not clear . SorryOrodruin said:This is incorrect.
As has already been discussed in the thread, friction must be equal to the horizontal component of the applied force.
No, when the block moves with a constant velocity it has zero acceleration.ALIAHMAD said:if i take acceleration to be zero I would give me the force that would not move the block
Then it would be kinetic friction that is relevant. The question relates to overcoming static friction.Mister T said:No, when the block moves with a constant velocity it has zero acceleration.
