Calculate the number of moles in a real gas
The original poster seeks assistance in calculating the number of moles of a gas mixture in a cylinder, given specific volume, pressure, and temperature conditions. The gas mixture consists of air with added oxygen, nitrogen, helium, and argon, and the poster has provided relevant parameters for the calculation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of the ideal gas law and the Van der Waals equation, noting discrepancies in the results. The original poster attempts to reconcile these differences and seeks clarification on the implications of using the Van der Waals equation.
Some participants have offered guidance on the use of quadratic equations and iterative methods to refine the calculation of moles. There is an acknowledgment of the complexity introduced by the Van der Waals parameters, and the discussion is ongoing with various interpretations being explored.
The original poster emphasizes the importance of accurately reflecting the pressure in the cylinder, which is noted to be 200 bar, and expresses a desire for a close approximation in the mole calculation.
larsb
I would like to know how to calculate how much moles of gas I have in the following in a cylinder with a certain volume and pressure.
The gas in the cylinder is a mixture of air, with added oxygen and helium, the mixture is 18% Oxygen, 36,6% Nitrogen, 45% Helium and 0,4% Argon. The cylinder is 24 liters big, the pressure in the cylinder is 200bar.
I can calculate the a and b values for the gas mixture.
P = 200 bar
V = 24 L
T = 293,15 K
R = 0,083145 L bar K-1 mol -1
a = 0,8746 L2bar mol-2
b = 0,0388 L mol-1
PV = nRT ( ideal gas law)
P = nRT (V-nb)-1 - n2a V-2
According to the ideal gas law this should be 196,93 moles, but that is not right, since if I use the Vanderwaals equation I end up at a pressure of 234,6 bar to accommodate 196,93 moles of this gasmixture.
Using the Vanderwaals equation I can't calculate the exact number of moles, this is where is end up:
200 = 24,37n (24 - 0,0388n)-1 - 0,00152n2
So please enlighten me, how can I proceed to calculate the value for n?
First, remember that the Van Der Waals pressure doesn't have to match the ideal pressure: in fact, it won't, unless a is 0. With an a as large as yours, the pressure can actually have quite a bit of variation between ideal and Van Der Waals.
For that last equation, have you considered quadratics?
You can apply some iteration procedure. Rewrite the Van der Waals equation in the form
[tex]n=\frac{PV}{RT}(1+\frac{n^2a}{PV^2})(1-\frac{nb}{V})[/tex]
Plug in the data, start with n you got for the ideal gas, substitute for n at the right side, and you get a new n. Continue the procedure with the new n... You get a value near 174 mol, if I am not mistaken.
ehild
Thanks, I know that it doesn't match the actual pressure and the ideal pressure do not have to match...
I know for sure that the pressure in the cylinder is 200 bar, or actually 201 bar, because I am reading the pressure from a gauge.
What do you mean by "considering quadratics"?
ehild
Ok, that indeed helps me a lot! I do not have to be completely spot on, however the closer the better.
