Calculate the position of the center of mass
The discussion focuses on calculating the position of the center of mass using the Theorem of Pappus. The user initially calculated the area of a composite shape consisting of a rectangle and a circle, leading to an incorrect volume calculation. The correct approach involves considering the shape as a cylinder minus a sphere when determining the volume. The user ultimately seeks clarification on the correct application of the theorem and the accurate calculation of the center of mass.
  • Theorem of Pappus
  • Basic geometry of composite shapes
  • Volume calculation of cylinders and spheres
  • Understanding of center of mass concepts
  • Study the Theorem of Pappus in detail
  • Learn how to calculate the volume of composite solids
  • Explore examples of center of mass calculations for various shapes
  • Investigate the geometric properties of cylinders and spheres
Students in physics or engineering, educators teaching mechanics, and anyone involved in geometric calculations related to center of mass and volume.
Robin04
I would like to calculate the position of the center of mass of the body on the figure.
http://kepfeltoltes.hu/150302/161353224K_pkiv_g_s_www.kepfeltoltes.hu_.jpg
I read a way of solution: Theorem of Pappus
It states that if we rotate our figure around an axis, the volume of the body we got will be equal to the product of area of the 2D figure and the distance traveled by the center of mass.
The axis I chose is at the right bottom tip of the figure, and it is vertical.
I determined the area of this figure: area of rectangle ((side = 2R) - area of circle (radius = R))/4 = (R^2*(4-π))/4
The distance traveled by the center of mass is 2πx.
The volume of the body: (volume of cube (side = 2R) -volume of shere (radius = R))/2 = (R^3(9-(4/3)π))/2
Now comes the theorem:
(R^2*(4-π))/4 * 2πx = (R^3(9-(4/3)π))/2
I got for x = (R(9-(4/3))/((4-π)π)
But if I try it with an example where R = 1 m I got for x = 1,78 m which is outside and completely non-intuitive. Can someone help me?
You got the volume wrong. It is not a cube minus a sphere. Not even a portion of a cube minus a sphere. Yes, that's a circular arc. You get part of a sphere when you rotate a cicular arc if you are rotating around the centre of the circle. But you don't get a cube when you rotate a square around an axis. Maybe you can get the answer as a cylinder minus a sphere.
Thank you ver much. :)
  • · Replies 19 ·
  • · Replies 25 ·
