Calculate the resistance per meter
The resistance per meter of a constant wire with a diameter of 1.25 mm and a resistivity of 5 x 10-7 Ωm is calculated using the formula R = ρL/A. The cross-sectional area (A) of the wire is determined to be 1.2 x 10-6 m2. By substituting the values into the formula, one can derive the resistance per unit length, confirming the relationship between resistivity, length, and area in electrical resistance calculations.
  • Understanding of electrical resistance and Ohm's Law
  • Familiarity with the concept of resistivity
  • Basic knowledge of geometry for calculating area
  • Ability to manipulate scientific notation
  • Learn about the relationship between resistivity and temperature in conductors
  • Explore the derivation of the resistance formula R = ρL/A in detail
  • Investigate the impact of wire diameter on electrical resistance
  • Study practical applications of resistance calculations in circuit design
Students studying electrical engineering, physics enthusiasts, and professionals involved in circuit design and analysis will benefit from this discussion.
looi76
Calculate the resistance per meter at room temperature of a constant wire if diameter [tex]1.25mm[/tex]. The resistivity of constant a at room temperature is [tex]5x10^-7\Omega{m}[/tex]
I'm not sure, but I think this is the right formula:
[tex]R = \frac{Pl}{A}[/tex]
[tex]Area = \pi \times \left(\frac{1.25 \times 10^{-3}}{2}\right)^2[/tex]
[tex]A = 1.2 \times 10^{-6} m^2[/tex]
What is Pl?
P is the resistivity and L is the length of the wire, so you are really solving for R/L
  • · Replies 21 ·
