Calculate the total energy of the mass spring system
The total energy of a mass-spring system with a 12 kg mass and a spring constant of 320 N/m, oscillating with an amplitude of 10 cm, is calculated to be 1.6 Joules using the formula ET=(0.5)(k)(A)^2. The maximum speed of the mass is determined to be 0.52 m/s, derived from the energy conservation equation. Additionally, when the mass is 5.0 cm from the equilibrium point, its speed is calculated to be 0.45 m/s, confirming the application of energy principles in simple harmonic motion.
  • Understanding of simple harmonic motion principles
  • Familiarity with Hooke's Law (Fx = -kx)
  • Knowledge of energy conservation in mechanical systems
  • Ability to manipulate equations involving kinetic and potential energy
  • Study the derivation of the maximum speed in simple harmonic motion
  • Learn about energy transformations in oscillatory systems
  • Explore the effects of varying mass and spring constants on oscillation
  • Investigate the damping effects in real-world mass-spring systems
Students in physics, mechanical engineers, and anyone studying dynamics and oscillatory motion will benefit from this discussion.
AClass
A 12Kg mass udnergoes simple harmonic motion with an amplitude of 10cm. If the force constant for the spring is 320 N/m
a) Calculate the total energy of the mass spring system.
b) Calculate the maximum speed of the mass
c) Calculate the speed of the mass when it is 5.0cm from the equilibrium point.
Fx= -kx
a=kx/m
ET=(0.5)mv^2 +(0.5)kx^2
Et=(0.5)(m)(A)^2
a)
ET=(0.5)(320 N/m)(0.10m)^2
ET= 1.6J
b)
1.6J=(0.5)(12kg)(V)^2 + (0.5)(320N/m)(0)
v=0.52m/s
c)
1.6J=(0.5)(12kg)(V)^2 +(0.5)(320N/m)(0.05m)^2
v=0.45m/s
Could someone verify this for me? Thanks
Those look correct to me (the method, I did not check the numbers).
1.a) E=1/2KA^2=1/2(320N/m)(0.1m)^2=1.6J b) V(max)=wA
  • · Replies 58 ·
  • · Replies 17 ·
