Calculate the total force on the Earth
  • Thread starter Thread starter anajonicholson
    Earth Force
The discussion revolves around calculating the total gravitational force on Earth due to the planets Venus, Jupiter, and Saturn, given their masses and distances from the Sun. Participants express confusion about the mass of Earth and the relevant equations needed for the calculation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants question how to proceed without knowing the mass of Earth, with one suggesting using a ratio approach. Others discuss the importance of identifying relevant equations and the setup of the problem, including the alignment of the planets.
The discussion is ongoing, with some participants offering guidance on starting points and approaches. There is a recognition of the need to clarify assumptions and gather more information about the problem setup.
Participants note the absence of a visual aid that is critical for understanding the configuration of the planets, which may affect the interpretation of the problem. There is also mention of the expectation that students should identify relevant equations independently.
anajonicholson
Calculate the total force on the Earth due to Venus, Jupiter, and Saturn, assuming all four planets are in a line, as shown in the figure. The masses are MV=0.815ME, MJ=318ME, MSat=95.1ME, and the mean distances of the four planets from the Sun are 108, 150, 778, and 1430 million km
I was not given relevant equations, but I am assuming it is F = Gm1 m2/r^2
I am confused how I am supposed to figure out the answer if I do not know the mass of the earth? Do I just set it to 1 and use m1 and m2 as ratios?
anajonicholson said:
Homework Statement:: Calculate the total force on the Earth due to Venus, Jupiter, and Saturn, assuming all four planets are in a line, as shown in the figure. The masses are MV=0.815ME, MJ=318ME, MSat=95.1ME, and the mean distances of the four planets from the Sun are 108, 150, 778, and 1430 million km
Relevant Equations:: I was not given relevant equations, but I am assuming it is F = Gm1 m2/r^2
Welcome to PF.
Yeah, I would start by doing that, then look up ME online and plug that into the final equation to get the total force. Can you show us that work?
Are all the planets on the same side of the Sun? You did not post the picture that goes with this. Also, don't expect a physics problem to give you the relevant equations for each problem separately. You are supposed to find which equation(s) is (are) relevant by reading the book. Nevertheless, you are supposed to post what you think is appropriate to make sure that you have thought about the problem and have done some background work. It seems that you have done that.
It is the weakest force in nature. The strength of the gravitational force is proportional to the product of the masses and inversely proportional to the square of the distance between them. so you can simply put values and add them all together.
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 32 ·
