Calculate torque required to accelerate question
  • Thread starter Thread starter ingram010
    Accelerate Torque
15 replies · 5K views
ingram010
Hi all
getting a bit stuck on this problem:-
a solid cylinder rotating about its polar axis has a mass of 120kg and a diameter of 0.6,. If the bearings provide a frictional torque of Nm, find the torque applied to accelerate the cylinder from 200 to 1400rpm in 40 seconds?
if anyone can provide the formula to solve this I will be very grateful
cheers
John
hi ingram010! :smile:
first use one of the standard constant acceleration equations to find the angular acceleration
then use torque = Iα :wink:​
Hi Tiny-Tim
I have solved the problem but I can’t work out how to factor in the loss of torque due to friction.
Is it just a case of deducting it from the applied torque?
Hope you can help
Cheers
John
Hi John! :smile:
ingram010 said:
… I can’t work out how to factor in the loss of torque due to friction.
That's right! :smile:
Torque, like any vector (ok, strictly it's a pseudovector :rolleyes:), is additive …
you found the angular acceleration, that tells you the total torque, so just subtract the friction torque to get the applied torque. :wink:
Great
so say the applied torque is 33.93Nm I just simply subtract the frictional torque which is 1Nm giving 32.93Nm?
It seems too simple to be true, but Ill go with it : )
Thanks for you help
Excuse me, why do you want to SUBTRACT ?
You need a force (torque) F to accelerate something. If you have a friction you'd need an ADDITIONAL force.
Do you agree ?
Are you sure about 33.93 Nm ?
Oh yes, whoops.
I have used the following equations to solve the problem:-
200rpm x 2 pi /60 = 20.94 rads/s = initial velocity
1400rpm x 2 pi /60 = 146.61 rads/s = final velocity
then
final velocity - initial velocity/40 seconds = 3.142 rads/s^2 = angular acceleration
then
mass x acceleration x radius^2 = Torque
so 120kg x 3.142 x 0.3^2 = 33.93Nm + frictional torque of 1Nm = 34.93Nm
Am I doing something wrong? I have to get this nailed as I have an exam on monday.
Did you mean
[tex]\tau = I \alpha[/tex]
torque = acc x inertia ?
So revise the cylinder inertia
ingram010 said:
… mass x acceleration x radius^2 = Torque
it would help you if you wrote things out properly
acceleration = 3.142
so total torque = 33.93
but total torque = applied torque minus friction torque
so applied torque (as asked for in the question) = …
(but your moment of inertia is wrong)
According to the book I have, inertia = mass x radius^2
so I = mass x raduis^2 = 10.8kgm^2
T= I x acc = 10.8 x 3.142 = 33.93
and
mass x acc x radius^2 = 120kg x 3.142 x .3^2 = 33.93
it gives the same answer, I am not sure what you are telling me
John
this is the extract from the book I am using:-
Torque, moment if inertia and angular motion
Torque
From Newton's third law, we know that to accelerate a mass we require a force such that:
F= ma
Now in dealing with angular motion, we know that this force would be applied at a radius r, from the centre of rotation and would thus create a turning moment or more correcxtly a torque T, thus
T = Fr or T = mar
Since the linear acceleration , a = rα(angular acceleration), then
T = m(rα)r or T = mαr^2.
Moment of inertia and angular motion
Now from our equetion for torque the quantity mr^2 has a special significance. It is known as the moment of inertia of the body about its axis of rotation. It is given the symbol I, thus: I = mr^2 and the units of I are (kgm^2), this is because the inertia of a body, from Newton's first law, is proportional to its mass multiplied by the distance squared.
Quite rightly I should have called it moment of inertia, but I still can't see what I am diong wrong.
the revised statement should read
According to the book I have, moment of inertia = mass x radius^2
Ahh!
Just found this, I really should spend more time reading.
Moment of inertia for a solid disk = 1/2 mr^2
Hi Tiny-Tim and Quinzio
I am sure that the answer to my question is 17.97Nm
Thank you both very much for your help
Kindest Regards
John
p.s If I am wrong please tell me : )
