Calculate Vertical Displacement at Point C with Virtual Loads in Truss
The discussion focuses on calculating the vertical displacement at point C of a truss structure using virtual loads. Participants are exploring the application of virtual forces and discussing the symmetry of the structure.
  • Technical explanation, Homework-related
  • One participant seeks assistance in calculating vertical displacement at point C after applying a virtual load of 1 kN.
  • Another participant notes an issue with the attachment containing the diagram necessary for the calculations.
  • A later reply claims to have calculated the vertical displacement to be 0.0172 mm.
Participants have not reached a consensus, as there are differing views on the calculations and the need for clarification regarding the diagram.
The discussion lacks clarity on the assumptions made in the calculations and the specific details of the truss structure, which may affect the results.
vtaela
Hi
I am trying to calculate the vertical displacement at point C for the following diagram
https://www.physicsforums.com/attachments/57161
So far i have calculated the forces in each member and i now need to calculate the Virtual forces!
I applied a virtual load at point c of 1 KN.
I also know that our structure is symmetrical!
Can you please help me to continue
Thank you
There's something wrong with your attachment. Please repost.
I have calculated tge vertical displacement to be 0.0172 mm
