How can I calculate the volume of leaked gas in a leak testing project?
  • Context: Undergrad
  • Thread starter Thread starter OffshoreEng
    Leakage Volume
The discussion focuses on calculating the volume of nitrogen leaking through a valve in a leak testing project. The upstream pressure is 4000 psi, while the downstream pressure after one hour is 4 psi in a contained volume of 100 ft³. By applying the ideal gas law, one can determine the mass of nitrogen that has leaked from Side A to Side B, given the fixed volume and pressure conditions. The assumption of temperature is crucial for accurate calculations.
  • Understanding of the ideal gas law (PV=nRT)
  • Knowledge of pressure measurement units (psi)
  • Familiarity with basic thermodynamics concepts
  • Experience with leak testing methodologies
  • Research the application of the ideal gas law in leak testing scenarios
  • Learn about pressure-volume relationships in gas systems
  • Explore methods for measuring gas leaks effectively
  • Investigate temperature effects on gas behavior in leak testing
Engineers, leak testing specialists, and professionals involved in gas system diagnostics will benefit from this discussion, particularly those focused on calculating gas volumes in high-pressure systems.
OffshoreEng
Hi,
I am working on a leak testing project in which i have a leaking valve and I am trying to determine the volume of nitrogen leaking through the valve.
Side A (upstream of valve) starts at 4000psi with an unknown volume. Side B (downstream of valve) starts at 0psi with a pressure contained volume of 100ft^3. After 1 hour, Side B now has 4psi. How can I calculate the volume of air that leaked through the valve from Side A to Side B?
I have attached a visual for a better understanding.
Thank you for your help.
Science news on Phys.org
You've got a fixed volume with a certain pressure inside. By making a reasonable assumption about the temperature of the gas inside, you can use the ideal gas law to calculate the mass of air (nitrogen?) which has leaked into Side B.
