Calculated Pitch, Yaw, Roll of vectors in a plane
The discussion revolves around determining the angles of rotation (Rx, Ry, Rz) applied to vectors in a Cartesian coordinate system after they have been rotated about the X, Y, and Z axes. Participants explore the mathematical implications of these transformations, particularly in relation to the original coordinate system versus the rotated coordinate system.
  • One participant expresses confusion about how to algebraically determine the angles of rotation given the new coordinates of the vectors after rotation.
  • Another participant suggests visualizing the problem using a sphere and describes the transformation as a rotation about the Z-axis followed by a rotation about the X-axis.
  • A link to resources on Euler angles is provided, emphasizing the importance of the order of rotations in transformations.
  • A participant clarifies their confusion regarding transformations about the original coordinate system versus the rotated coordinate system, questioning the implications of rotation definitions.
  • The iterative solution method is proposed as a way to solve for the applied rotations, with references to rotation matrices and their properties.
  • There is a discussion about whether the iterative solution will yield rotations about the original coordinate system, with emphasis on maintaining identical orientation during transformations.
Participants have not reached a consensus. There are competing views on the nature of the transformations and the implications of using different coordinate systems for rotations.
Participants note the complexity of defining rotations in relation to different coordinate systems and the potential for confusion arising from the mathematical definitions of transformations.
nschaefe
Hello, I'm sorry if this is a dumb question but I am extremely confused and could use some guidance.
So consider a cartesian coordinate system with a plane which passes through the origin, and there are vectors of known X,Y,Z components which lie within this plane. The plane(and vectors) are then rotated about the X,Y, and Z axes by some unknown angles wrt the origin. Assume that the plane is initially parrallel with the XY plane and has a rotation about Z of 0
Given the new coordinates of the vectors after rotation, is there a way to algebraically determine the angles of rotation Rx, Ry, and Rz that were applied?
My original approach was based on finding the planes unit normal vector (N), then calculating Rx = atan(Ny/Nz) and Ry = atan(Nx/Nz), and using one of the vectors (V) to calculate Rz = atan(Vy/Vx), but I am realizing this is incorrect. Is this even possible? Thanks for taking a look.
Mathematics news on Phys.org
hello nschaefe! welcome to pf! :smile:
i think it's easiest if you imagine everything on a sphere, with north along the z-axis and longitude 0 along the x-axis
let the first plane cut the sphere along the equator, and the second plane along a great circle that intersects the equator at longitudes φ and 180°+φ, and with an angle θ between it and the equator
then the transformation would be a rotation of φ about the z-axis, followed by a rotation of θ about the x-axis :wink:
This link may help ...
http://en.wikipedia.org/wiki/Euler_angles
I'm sure the PF contributors can cover this topic perfectly well, but you may also want to look further afield. This question crops up all the time in the field of navigation, so resources related to that area may also shed some light. The link above will set you off down that route. The order of the rotations is important, and there are some conventions discussed here ...
http://mathworld.wolfram.com/EulerAngles.html
Thank you both for your responses. I think my part of my confusion is because I want the transformations to occur about the original coordinate system.
Looking at the image from the wolfram site:
The final transformation appears to be taken about the rotated coordinate systems z axis (the angle [itex]ψ[/itex]), also appearing in this text below:
1. the first rotation is by an angle phi about the z-axis using D,
2. the second rotation is by an angle theta in [0,pi] about the former x-axis (now x') using C, and
3. the third rotation is by an angle psi about the former z-axis (now z') using B.
What I want are rotations about the original coordinate system (xyz), i.e. [itex]\theta[/itex]x, [itex]\theta[/itex]y,[itex]\theta[/itex]z which yield the rotated points.
I am wondering if this is due to the definition of rotation being a coordinate system transformation vs. a transformation of the points themselves. From what I have gathered from the wikipedia article on rotation matrices, switching the sign of the sin terms in the rotation matrix yields a point transformation vs. a coordinate system transformation. However, isn't this irrelavent as it is really just the idea of rotation by a negative angle vs. a positive one? (i.e. -20 degrees coordinate system transformation is equivalent to +20 degrees point transformation)
Of particular interest however were equations 71-77 of the wolfram math page, and funny enough was an solution I originally conceived but then disregarded.
Essentially given X as an original point and X' as the rotated counterpart due to applied rotation transformation A, (i.e. X' = AX), you can use a nonlinear iterative solution method to solve the applied rotations.
So if A = R_x*R_y*R_z (where R_x is the rotation matrix of some angle about X, then the Jacobian of A with respect to [itex]\theta[/itex]x, [itex]\theta[/itex]y,[itex]\theta[/itex]z can be used to solve the rotations that occurred.
Thus my question is this: Using the iterative solution outlined above (see the wolfram math page at this link, and using the rotation matrices outlined in this wikipedia article, will the solution give me rotations [itex]\theta[/itex]x, [itex]\theta[/itex]y,[itex]\theta[/itex]z about the original coordinate system xyz?
Worded another way, if I were to take some points and apply a three transformations (R_x,R_y,R_z), all of these rotations should be occurring about the "same" coordinate system, i.e. coordinate systems with identical orientation, correct?
I hope this makes sense, thanks for all your help and let me know if you need any clarification.
  • · Replies 16 ·
15K
  • · Replies 51 ·
16K
