Calculated Young's Modulus smaller than typical value (steel)?
The calculated Young's Modulus from the experiment using an extensometer was found to be 11 GPa, significantly lower than the expected value of 200 GPa for steel. The discrepancy likely arises from incorrect plotting of stress versus strain, as Young's Modulus is determined from the initial slope of this graph. It is crucial to ensure that the stress is measured in GPa and strain is dimensionless, focusing on the tangent to the curve at low stress values for accurate results.
  • Understanding of stress-strain relationships in materials
  • Familiarity with Young's Modulus and its significance in material science
  • Experience with plotting graphs and interpreting data
  • Knowledge of extensometer usage in experimental mechanics
  • Review the principles of stress-strain curves in material testing
  • Learn how to accurately calculate Young's Modulus from experimental data
  • Investigate the proper use of extensometers in tensile testing
  • Study the linear elastic region of steel and its implications for material properties
Students in materials science, engineers conducting tensile tests, and researchers analyzing mechanical properties of materials will benefit from this discussion.
MegaDeth
I carried out an experiment using a extensometer, had a range of values for the elongation and load. I calculated the value from the data and had 11GPa whereas it should be 200GPa. Do you know what could have gone wrong? Thanks a lot.
Are you sure you plotted stress (in GPa) versus strain (dimensionless)? If you are looking for Youngs Modulus, you need to look at the initial slope of the graph you plot (i.e, tangent to curve at low stress value, although for steel the curve should be close to linear below the yield stress).
  • · Replies 29 ·
  • · Replies 33 ·
13K
18K
