Calculating a push force using area, speed, and density?
8 replies · 6K views
struggtofunc
The doorway in the previous question measures 1.06 m x 2.04 m, and the wind blows parallel to the wall surface at 3.89 m.s-1. Calculate the force pushing the curtains out of the doorway. The density of air is 1.29 kg.m-3.
Known data:
A = (1.06m)(2.04m) = 2.162 m^2
v(wind) = 3.89 ms-1
air density = 1.29 kg.m-3
F=ma
P=F/A
change in P = (density)(g)(h) ?
= (1.29) (9.8) (2.04)
= 25.79 Pa
P = F/A
F = PA
= (25.79)(2.1624)
= 55.77 N
I know my method is most likely wrong but I'm not too sure what other equations I could use, especially one that involves the velocity of the wind.
So using Bernoulli's equation:
P1 + (½ * ρ * v1^2) + (½ * ρ * g * h1) = P2 + (½ * ρ * v2^2) + (½ * ρ * g * h2)
Because the wind is flowing parallel, it would be considered horizontal allowing me to cancel out the heights giving me the equation of
P1 + (½ * ρ * v1^2) = P2 + (½ * ρ * v2^2)
Now I'm expecting to be able to calculate P1 and then use F=PA to calculate the final answer (I'm given the area and would calculate P).
However, because this is a before and after type equation, how would I calculate P1 without a value for P2? I am completely stumped. Thanks for your help!
You get a pressure difference, that is sufficient. The absolute pressure does not matter (apart from its influence on the density, but that is taken into account already).
I'm really sorry but I think I am confusing myself now.
I've rearranged P1 + (½ * ρ * v1^2) = P2 + (½ * ρ * v2^2) to become
P1-P2= ½ * ρ ( v2^2 - V1^2). This would allow me to get a change in pressure.
However, Velocity is not changing so i would be getting a 0 value for v2^2 - V1^2 and wouldn't be able to progress the equation. Am I still on the right track?
There is no changing velocity, but there is a different velocity. One velocity is zero, the other is not.
Oh yes, I see. Thankyou very much!
Using that then:
change in pressure = 1/2 (1.29)(3.89^2)
= 9.7602045 Pa.
Am I now right to believe that I can use this value in P=F/A to calculate force?
It is a change in pressure so I'm unsure what 'types' of pressure to use in this calculation and why absolute pressure is not considered.
Edit: My calculations for force using P=F/A gives me an answer of 21.105 N
If you have the same pressure on both sides it doesn't influence the door. Only the pressure difference matters.
Looks fine.
Thank you so much! I really appreciate the help :)
