Calculating Alpha: Intercept & K
  • Thread starter Thread starter nothingatall
    Alpha
To calculate alpha using the intercept and k, the formula T = 2π(m + (alpha)mspring)/k must be applied correctly. The user found an intercept of 0.228 and k as 5 kg/s², but is uncertain about the relevance of the intercept in the calculation. Clarification is needed on how to incorporate the intercept into the formula and the appropriate axes for graphing T²/g. Additionally, understanding which of Hooke's laws applies and defining alpha are crucial for resolving the confusion. Accurate application of these concepts will lead to the correct calculation of alpha.
nothingatall
calculate alpha using the intercept and the value of k.
T= 2pi*(m+(alpha)mspring)/k)^1/2
my intercept i found using EXCEL was .228 and k=5kg/s^2 which I'm pretty sure i did wrong. But i don't know how my intercept would have anything to do with this. and where to plug the intercept into. My slope turned out to be S^2/ g when i was asked to graph T^2/ g. A little help? thanks
What are your x and y axes? Can you attach the graph? Which one of Hooke's laws is relevant? Define alpha.
  • · Replies 22 ·
