Calculating amount of H2SO4 needed for dilution
The discussion revolves around a homework problem concerning the dilution of hydrochloric acid (HCl) and the calculation of the volume needed to achieve a specific molarity. Participants are attempting to verify their calculations and clarify the problem statement.
  • Homework-related
  • One participant sets up the dilution equation M1V1 = M2V2 correctly but questions their calculated volume of 0.005L.
  • Another participant confirms the setup of the equation but suggests that the calculated volume is incorrect and encourages re-evaluation of the calculation.
  • There is a suggestion that the problem statement may contain a typo regarding the target concentration, with one participant proposing it should be 0.200M instead of 0.400M.
  • Participants express confusion over the multiple-choice answers provided, with one participant indicating a preference for the smallest value but noting it does not match their calculation.
  • There is a question raised about whether the acid in question is HCl or H2SO4, indicating potential ambiguity in the problem statement.
Participants do not reach a consensus on the correct interpretation of the problem statement or the accuracy of the calculations. Multiple competing views regarding the correct concentration and volume remain unresolved.
Participants note potential typos in the problem statement and express uncertainty about the correct answers provided in the multiple-choice options. The discussion reflects varying interpretations of the problem parameters.
LegitSci
How much 4.00M of HCl is required to make 100ml of 0.400M HCl?
M1V1 = M2V2
Its (4.00M)*(xL) = (0.400M)(0.100L)
I think its 0.005L but the possible answer (multiple choice) say otherwise...
I just need confirmation if i did it right or i messed up on something
Thanks
This equation is setup correctly.
But the number you get is incorrect. Try re-doing the calculation.
They ask you how much of a solution is required to make (100 ml of) a solution a tenth as concentrated and you need a formula?
The question should say How much 4.00M of HCl is required to make 100ml of 0.200M HCl?
Oops typo, I meant to say (4.00M)*(xL) = (0.200M)*(0.100L)
but the multiple options are 0.000125L, 1250ml, 125 ml, 50,000ml
so please advise
naturally, i'd want to pick the smallest value which is 0.000125L, but its not what i got
Must be a mistake in the test (assuming you finally listed the problem and answers right).
LegitSci said:
4.00M of HCl
... or, 4.00 M H2SO4?
So the thread Subject is wrong?
11K
39K
10K
