Calculating Amplitude for a Spring Oscillation with Hooke's Law
  • Thread starter Thread starter Dark Visitor
    Amplitude Spring
The discussion revolves around calculating the amplitude of oscillation for a spring system using Hooke's Law. The original poster describes a scenario involving a 2 kg block attached to a spring, with a specified amount of energy supplied to stretch the spring and a given oscillation period.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss relevant equations related to spring motion, including those for energy, force, and period. There are attempts to derive the spring constant and initial displacement from the given energy and period.
Several participants have provided guidance on the equations to use and the relationships between variables. There is an ongoing exploration of the calculations needed to find the amplitude, with some participants questioning their own results and clarifying the definitions of amplitude in the context of simple harmonic motion.
Participants note potential confusion regarding the definitions of amplitude (peak-to-peak versus maximum displacement) and the algebraic manipulations required to derive the necessary values. There are references to specific numerical results that have led to discrepancies in understanding.
Dark Visitor
I attach a 2 kg block to a spring that obeys Hooke's Law and supply 16 J of energy to stretch the spring. I release the block; it oscillates with period .3 s. The amplitude is:
* 38 cm
* 19 cm
* 9.5 cm
* 4.3 cm
Can anybody help me with this? I can't figure out what to do or where to start. It seems so easy, but I can't get it. Thanks.
Do you recall seeing an eqn T=2*pi*sqrt[k/m] . I think that is it. So solve for K by squaring both sides. Recall that energy is 1/2 k x^2 and is equal to 16J. Solve for x. This will be the initial stretch. In SHM, this constant represents 1/2 amplitude.
Could you list the spring formulas you have to work with? There should be one with force, one with energy and one with period or frequency.
To Denverdoc: Yes, but on my notes, I have:
T = 2[tex]\pi[/tex]*[tex]\sqrt{}m/k[/tex]
To Delphi51: I will list the ones I see here with me.
Potential Energy: Usp = 1/2(k)(xs)2
(k is spring constant, xs is compression/extension of spring from relaxed position)
Fs = -kxs
Wby sp = 1/2(k)(xs,i)2 - 1/2(k)(xs,f)2
Those are the only ones I see at the moment.
Yes you're right I forgot to flip it in going from w to T. So you have enough to solve it. Just follow the instructions in my last post.
It's all good. I do have a question: You said in your last post that to solve for K, I had to square both sides. It seems to me that I have to do much more than that. Am I right?
Sure, there is some simple algebra as well. Remember that is to just get K. You still have the other things to do as outlined in my post.
Well, when solving for k, I got:
k = m/(t/2[tex]\pi[/tex])2
is that right?
Yes (but by convention capital T is used for the period to avoid confusion with time.)
Fs = -kxs
He's right make sure T=t in your terms or you could end up with anything.
Exactly right.
Yeah, I just missed hitting the shift key when typing, or I typed it too fast. I do know the difference, and wouldn't get confused.
Well, I did that and got
k = 2 kg/(.3 s/2[tex]\pi[/tex])2
= 9.006
Very well. I like that it is round. Now it's perfectly ok to go back and reread my earlier posts as to how to proceed, remember we are looking for x, the initial displacement which is 1/2A.
Again he's right more mistakes come from mixing up terms than everything else.
[tex]a\neq{x}[/itex]<br /> <br /> [tex]c\neq{C}[/itex]<br /> <br /> And so on.<br /> <br /> <blockquote data-attributes="" data-quote="Dark Visitor" data-source="post: 2479676" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> Dark Visitor said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Yeah, I just missed hitting the shift key when typing, or I typed it too fast. I do know the difference, and wouldn't get confused.<br /> <br /> Well, I did that and got<br /> <br /> k = 2 kg/(.3 s/2[tex]\pi[/tex])<sup>2</sup><br /> = 9.006 </div> </div> </blockquote><br /> Looks good to me?<br /> <br /> What expectation value were you expecting for k?[/tex][/tex]
Okay. Now I solved for x:
E = 1/2(k)(x)2
16 J = 1/2(9.006)(x)2
x = [tex]\sqrt{}(32 J/9.006)[/tex]
= 1.885
So that means that 2x is my amplitude? so all I need to do is double my x and get my final amplitude value?
Indeed. Sounds like you have this all figured out gj.
If the question is looking for peak to peak amplitude, yes. Remember your cos or sin function will vary between 1 and -1.
The initial displacement becomes the A on the outside of the SHM type of eqns you have been writing this weekend. Since it is simple harmonic motion, the initial displacement determines the subsequent behavior. Had we stretched the string more initially, the A would be different. Imagine a pendulum. If there is no friction, the ball swings back and forth to and from ther release point--same principle here.
For simple harmonic operators this might help? Don't know?
https://www.physicsforums.com/showthread.php?t=219445&highlight=Wilson-Sommerfield
Helped me though.
I think I understand. My only issue now is, when I got 3.77 m as my A, how is the answer 38 cm? Did I mess up somewhere with my math?
Order of magnitude?
http://en.wikipedia.org/wiki/Order_of_magnitude
ttp://upload.wikimedia.org/math/2/e/1/2e144dcb120e3ba404112929f2ff82f5.png
what's the answer to x dp?
I don't know. I got 3.77 m, which converts to 377, or 380, cm. But my answer is 38 cm. I don't see what I did wrong...
So what do I do? I can't find where my error is...
i found it--it is in the algebra for computing K. You have it flipped a bit, 2 pi should be in the numerator. k=219.32 when you do this, you will get .38m but it isn't doubled. It is not asking for peak to peak amplitude but just one leg. Sorry, I should have checked that more carefully and the round number lulled me into a false sense of security.
Mod note:
Deliberate attempts to confuse the OP, and responses, have been deleted.
Why is 2[tex]\pi[/tex] in the numerator? That's not the equation I had written down...
I do have another one that says:
Tspring/mass = 2[tex]\pi[/tex]/[tex]\sqrt{}k/m[/tex]
thanks.
Why thanks? And why would we use that one now?
T=2*pi*(sqrt (m/k)) Remember the rule about dividing being equal to mult by the reciprocal:
a/b/c/d= ad/bc.
Sorry--the thanks was to the moderator for removing some confusion. But this whole thread seems hopelessly confused. Nevertheless, do the algebra carefully and you will get an answer for x=0.38m which is what we wanted!
  • · Replies 27 ·
10K
