Calculating angles between matrices
  • Level: Graduate
  • Thread starter spicytaco
    Angles Matrices
4 replies · 20K views · last reply
spicytaco
Hey all,
I was hoping someone could explain to me how to calculate the angle between matrices, ie. two square matrices
[ 2 0
0 -1]
and
[0 1
1 3^(1/2)]
under the inner product <A|B> = trace (A^TB)
Also, how would you go about determining an angle between x and y when they are functions, ie. x = f(x) = x^2 +2 and y=(g(x)=x^3 -7x, under the inner product below:
⟨f |g⟩ =
∫ f (x)g(x)dx.
−1
I already know how to determine angle using cos theta = (x^Ty)/ ||x|| ||y|| but does this only work for column and row matrices?
Any time you have an inner product, you can use it to define angles between elements using the usual formula:
[tex] \cos\theta(a,b) = \frac{\langle a | b \rangle}{\sqrt{\langle a | a \rangle \langle b | b \rangle}}[/tex]
This works equally well for your matrices and for your functions.
Whether that angle tells you anything useful for the problem you're trying to solve is another question. :)
For "vectors in space", two or three dimensions, you can use trigonometry to prove that the dot product of two vectors, u and v, are given by [itex]u\cdot v= |u||v|cos(\theta)[/itex] where |u| and |v| are the lengths of the two vectors and [itex]\theta[/itex] is the angle between them. For more abstract vector spaces, we define the length of a vector, v, to be [itex]\sqrt{<v, v>}[/itex] and the angle between u and v to be given by
[tex]cos(\theta)= \frac{<u, v>}{|u||v|}[/tex]
In spicytaco's matrix example the angle is the same as the angle for the two vectors (2,0,0,-1) and (0,1,1, 3^1/2) in R^4 with usual euclidean norm.
(2,0,0,-1).(0,1,1,3^1/2) = 0 + 0 + 0 - 3^1/2
|(2,0,0,-1)| = 5^1/2
|(0,1,1,3^1/2)| = 5^1/2
so cos(theta) = (-3^1/2)/5 (theta ~= 110 degrees)
this is why the inner product is defined as trace(A^T.B), for nxn matrices you get R^(n^2) euclidean space with two vectors defined by joining the columns of A and the other by the columns of B.
For the functions example there isn't a "natural" analogy but the answer has been given above, you just plug in the formula for the inner product into the equation for cos(theta)
