Calculating Angular and Linear Speed and period of revolution
The discussion revolves around calculating the angular speed, linear speed, and period of revolution for a toy truck moving in a circle with a radius of 0.6 meters at 2 revolutions per second. The angular speed is calculated as 12.56 radians per second, derived from the formula ω = 2π/T, where T is the period of 0.5 seconds. The linear speed is determined using v = rω, resulting in a speed of 7.54 m/s. The period of revolution is confirmed to be 0.5 seconds, aligning with the truck's rate of 2 revolutions per second. The calculations are validated, with corrections made to ensure accuracy in the results.
FaraDazed
A toy truck moves around the outside of a circle of radius 0.6m at 2 revolutions per second
Calculate:
a: the angular speed of the truck
b: the linear speed of the truck
c: the period of revolution
<br /> ω= \frac{2π}{T} \\<br /> v=rω<br />
For part a i have done..
<br /> ω= \frac{2π}{T} \\<br /> ω= \frac{2π}{0.5} \\<br /> ω= 12.56 rads/s<br />
I used 0.5 as it says it rotates twice per second so one rotation would take half a second (i think this maybe wrong).
For part b i have done..
<br /> v=rω \\<br /> v=0.6 \times 12.56 \\<br /> v= 7.54m/s \\<br />
Obviously this depends on whether I got part a correct.
For part c I am not sure what the question is asking for but at a guess I did what I did in part A..
2 revolutions per second, therefore 1 revolution would take 0.5s.
Any help is appreciated.
What is 2 divided by .5? Last time I checked it was 4.
I understand that, but where does that relate to my answers? Have I divided 2 by 0.5 anywhere?
I do usually miss obvious things, and I can't see this one, could you point it out please?
EDIT: sorry I just released this mistake (i think) and rectified it.
Last time I looked your first answer was 3.14 rad/sec for angular velocity. Now it has been changed to 12.56 radians/sec.
I am not a native English speaker but I think it means the time one rotation takes. So for c T=0.5s
Could anyone have another look please and see if there is anything wrong with it now? Any help is appreciated :)
It is correct. Angular speed is 4*pi; linear speed is 2.4*pi; period is 0.5 seconds.
  • · Replies 18 ·
