Calculating Angular Momentum of a Rotating Disk with a Point Mass on the Rim
The discussion focuses on calculating the total angular momentum of a system consisting of a rotating disk and a point mass (a woman) on its rim. The woman has a mass of 45.0 kg, the disk has a mass of 120 kg, and the disk rotates at an angular velocity of 0.490 rev/s, which converts to 3.079 rad/s. The correct formula for angular momentum, L = I(omega), requires the moment of inertia for both the disk and the point mass to be calculated separately and then summed. The moment of inertia for the disk is (1/2)mr^2, while for the point mass, it is mr^2, leading to a total angular momentum of 5143.8 kg m²/s when calculated correctly.
  • Understanding of angular momentum and its formula L = I(omega)
  • Knowledge of moment of inertia for different shapes, specifically disks and point masses
  • Ability to convert angular velocity from revolutions per second to radians per second
  • Familiarity with basic physics concepts related to rotational motion
  • Study the derivation of the moment of inertia for various shapes, including disks and point masses
  • Learn how to calculate angular momentum for composite systems
  • Explore the implications of treating objects as point masses versus extended bodies in physics
  • Investigate common pitfalls in rotational dynamics calculations and how to avoid them
Students studying physics, particularly those focusing on rotational dynamics, as well as educators seeking to clarify concepts related to angular momentum and moment of inertia.
ph123
A woman with a mass of 45.0 kg is standing on the rim of a large disk that is rotating at an angular velocity of 0.490 rev/s about an axis through its center. The disk has a mass of 120 kg and a radius of 4.50 m. Calculate the magnitude of the total angular momentum of the woman-plus-disk system. (Assume that you can treat the woman as a point.)
Ok, well I first converted rev/s into rad/s.
0.490 rev/s * 2(pi) = 3.079 rad/s
Next I determined that the moment of inertia for a disk is
(1/2)mr^2
Next I used the equation for angular momentum:
L = I(omega)
= [(1/2)mr^2]omega
= [(1/2)(120 kg + 45 kg)(4.50m)^2]*3.079 rad/s
= 5143.8 kg m^2/s
This one seemed really straightforward to me, but the program I use for physics says the answer isn't right. Anyone know what I did wrong?
I believe you omitted the radius squared term for the disk in your next to last eqn.
Aside from the fact that one should never treat women as points, I think the problem is that she has a factor of (1/2) on her. Her moment of inertia is m*r^2.
right, they hate to be treated as point objects. :mad:
You're right I didn't see that the R^2 was factored out, and the 1/2 also factored. Its funny you get used to seeing things presented a certain way the errors in perception one can make at a glance. I even looked twice.
I've looked more than twice and still been wrong. See my most recent fiasco in thermodynamics...
How is the woman mr^2. Is she considered a hollow cylinder? If so, then, I have to add the momentum of the disk itself and then the momentum of her separately? How do account for the fact that she is on the disk, such that the disk is heavier with her on it?
Point mass I=mR^2 which you are advised to treat her as, this eqn is one of the few moment of inertias that follows immediately from its definition
The disk isn't 'heavier'. It just has a normal force acting on it - which doesn't affect its moment of inertia. The moment of inertia of the hollow cylinder and a point mass are both mr^2 for the same reason - all of their mass is concentrated at the rim.
ive got this same question, and i am clueless on where to go
Just add the moments of inertia of the point-woman and the disk and multiply by the angular velocity. If that's not enough of a clue, then I'd suggest you repost the question so others can help. Resurrecting old threads is a bad idea. They have too much confusing baggage attached.
ph123 said:
... but the program I use for physics says the answer isn't right. ...
Hello Ph123
What is the program you use for physics?
C
they are both mr^2 right?
  • · Replies 45 ·
  • · Replies 17 ·
