Calculating Average Electrical Energy Dissipated in Copper Wire Loop
A copper wire loop with a radius of 12 cm experiences an increasing magnetic field from 0 to 0.55 T over 0.45 seconds. To calculate the average electrical energy dissipated, the average induced electromotive force (emf) can be found using the formula emf = N(dΦ/dt), where N is the number of turns. The resistance of the wire, given as 3.3*10^-2 ohms/m, must be multiplied by the circumference of the loop to convert it to ohms. The correct approach involves using the calculated emf in the power formula P = V^2/R to find the energy dissipated over the given time. The discussion concludes with the realization that the initial method using current was unnecessary and that the emf approach is more straightforward.
spoonthrower
A piece of copper wire is formed into a single circular loop of radius 12 cm. A magnetic field is oriented parallel to the normal to the loop, and it increases from 0 to 0.55 T in a time of 0.45 s. The wire has a resistance per unit length of 3.3*10^-2 ohms/m. What is the average electrical energy dissipated in the resistance of the wire
I know that P=V^2/R
So i need to find the voltage in the wire.
To find the voltage, can i just find the average induced emf or is this approach wrong??
If i use the equation: average induced emf=BA/T i get the wrong answer simply calculating the area from the radius of the circle .12^2*pi.
Please help! what am i doing wrong?
I can't see that your doing anything wrong here. Have you mulitplied the resistatance by the length of the wire (the circumference of the circle)? Also have you converted the power into energy (E = P.t)? Perhaps, if you show your calcs...
~H
Since the wire is in a loop i guess i have to use this equation to find the current:
B=N(u)I/(2R) where u=4pi*10^-7 and N=# of turns=1 and R=Radius in meters
solving for I to get I= 105042.2624 A
This is a huge # so i don't know if I am doing this right.
Power=I^2R where I is the current through the wire and R is the resistance in ohms. so this leads to my next problem. the problem gives me the resistance in ohms/m so i assume i have to multply this resistance by the length (circumference) of the wire to change it into ohms. so the circumference of my wire is .12(2)pi= .753982237 m. so my resistance would be .753982237 m(3.3*10^-2 ohms/m) to get .024881414 ohms.
now that i know both I and R i can plug them into power=I^2R
=(105042.2624)^2(.024881414)= 274538456.9 W
So power= energy/time so energy=power(time)=274538456.9(.45)=1.24*10^8 J.
This is not the correct answer. Please let me know what i am doing wrong. thanks.
Why are you using current? It would be much easier to find the emf generated as you are given all the required information in the question;
emf = N\frac{d\Phi}{dt}
You can then sub this value into;
P = \frac{V^2}{R}
as you originally suggested. You were correct in you method for find the resitance, area of loop and it circumference btw.
~H
thanks for your help. i got the right answer.
In the Biot-Savart formula "B = uNI/2R" , the I *causes* the B-field.
Certainly a static Magnetic field cannot cause charge to move.
