Calculating capacitance of capacitor filled with 2 dielectrics
The discussion focuses on calculating the capacitance of a capacitor filled with two different dielectrics. The initial approach involved integrating the elemental capacitors as a parallel combination, which led to an incorrect answer. A subsequent attempt to treat the elemental capacitors as being in series yielded the correct result. The user is seeking clarification on the mistake made in the initial parallel assumption. Assistance is requested to identify the flaw in the first method.
darkv0id
A capacitor is formed by 2 square metal plates of edge a and separated by distance d. Dielectrics of dielectrics constants K1 and K2 are filled in the gap as shown.
2. The attempt at a solution
This was my initial approach:
I integrated the parallel combination of elemental capacitors dC1 and dC2, but I didnt get the correct answer.
Next, I tried taking the elemental capacitors in series instead of parallel:
This time my answer turned out to be correct.:smile:
Can someone help me identify the flaw in my initial approach? I suspect I was wrong in assuming that the elemental capacitors were in parallel in the first place.
Opinions?
Anyone ?
No one?:frown:
Please, can anyone help me out?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
