Calculating Charge Transfer between Objects
  • Thread starter alithefickle
    Electrons
alithefickle
Hi everyone, would you kindly help me with our homework..Although our teacher was able to give the final answer but he couldn't find a solution that will result to the answer.tsk tsk tsk. Here is the problem.
A Plate carries a charge of -3.0 uC, while a rod carries a charge of +2.0 uC. How many electrons must be transferred from the plate to the rod, so that both object have the same charge?
The final answer given by the teacher is:
1.6 x 10 exp 13 electrons
Would you kindly give me the solution on how the book came up with this answer? Many thanks..cheers!
q = Ne
N = q/e
Welcome to PhysicsForums!
We don't do your homework for you here, but we'll work with you. First off, when they're touched together, what happens? What is the final charge on each object? How many electrons is this?
electrons are transferred to the other material.. Final charge for plate = 4.8 x10 exp-25
for rod is -3.2 x 10exp-25...Im not sure if this is correct...would you kindly check.tnx
