Calculating cos(2nπ/3)/(n²) using the Sum of Series 1/n²
  • Thread starter Thread starter andrey21
    Series Sum
The discussion revolves around calculating the series involving cos(2nπ/3)/(n²) using the known sum of the series 1/n², which equals (π²/6). Participants explore the behavior of the cosine function at integer multiples and its implications for the series.
  • Participants discuss calculating cos(2nπ/3) for various integer values of n to identify patterns. There are inquiries about the periodic nature of the cosine function and how it affects the series. Some participants suggest splitting the series based on the values of n.
The discussion has progressed with participants sharing calculations and observations about the series. Some guidance has been offered regarding evaluating specific sums and recognizing patterns in the cosine values. There is an ongoing exploration of how to combine the results from different series.
Participants mention the need to evaluate sums involving terms like (3n)² and (3n+1)², indicating a focus on manipulating series terms to derive the final result. There are also references to the challenge of obtaining exact values versus approximations in the context of the series.
  • #31
Yes! So that's the first sum. Now try to evaluate
[tex]\sum_{n=1}^{+\infty}{\frac{1}{(2n+1)^2}}+\sum_{n=1}^{+\infty}{\frac{1}{(2n+2)^2}}[/tex]
  • #32
Ye ok is it (2n+2)^2 or (3n+2)^2? Just in the first page it was 3 not 2 before the n.
  • #33
Ow, my apologies, it is 3 instead of 2...
  • #34
Ok so from the two sums I get:
1/(9n^2+6n+1)
and
1/(9n^2 +12n+4)
  • #35
Hmm, you won't be able to calculate those sums separately...
You'll have to use the following:
[tex]\sum_{n=1}^{+\infty}{\frac{1}{n^2}}=\sum_{n=1}^{+\infty}{\frac{1}{(3n)^2}}+\sum_{n=1}^{+\infty}{\frac{1}{(3n+1)^2}}+\sum_{n=1}^{+\infty}{\frac{1}{(3n+2)^2}}[/tex]
You know two of the above series...
  • #36
Rite so what your saying is:
Pi^2/6 = Pi^2/54 + SUM 1/(3n+1)^2 + SUM 1/(3n+2)^2
  • #37
Yes, so you've found the values to all the series!
  • #38
Ah ok so:
Pi^2/54 - 1/2(Pi^2/6 - Pi^2/54) = Sum of series
  • #39
Yes! Very good!
  • #40
Thanks Micromas you have been great help. Out if curiosity how did you obtain the equation in post 35 ??
  • #41
Well, in post 14, we were asked to calculate those two sums. I first tried to evaluate them separately, but that didn't work. So then I came up with that solution. I guess it's a bit experience from my part. The more problems you solve, the more tricks you know. You also know the trick now :smile:
  • #42
Haha ok thanks again micromass:smile:
  • #43
I just finished my calculations and ended up with value of -3Pi^2/54 for sum of series. Is this correct?? Thanks in advance
  • #44
Yes, I believe that is correct!
  • · Replies 17 ·
