Calculating Effects of Collisions in Series - Melissa
  • Context: Undergrad
  • Thread starter Thread starter MelissaSweet
    Collisions Series
The discussion revolves around calculating the effects of a series of collisions involving multiple bodies, specifically focusing on a three-body collision scenario. Participants explore the dynamics of inelastic collisions, momentum conservation, and the mathematical modeling required to determine the distance traveled by one of the bodies relative to an observer.
  • Melissa seeks a simple method to describe a series of collisions and questions whether effects can be calculated collectively or must be addressed individually.
  • Some participants inquire about the context of the collisions, suggesting that the nature of the objects involved (e.g., neutrons, cars) could influence the approach to the problem.
  • Melissa describes a three-body collision scenario where body x is stationary, body y is moving to intercept it, and body y2 will subsequently collide with the combined system.
  • Patrick explains the concept of inelastic collisions and momentum conservation, suggesting that the total momentum before and after collisions can be used to calculate the resulting velocities.
  • Melissa expresses the need for a formula to determine the distance body x travels in the trajectory relative to the observer, indicating that time may need to be factored into the calculations.
  • Patrick provides an analogy involving trains to illustrate how to approach the problem of determining when and where the bodies will collide.
  • Melissa acknowledges that each calculation appears to be a separate function, confirming the complexity of the problem.
Participants generally agree on the necessity of using momentum conservation for solving collision problems, but there is no consensus on whether there are alternative methods. The discussion remains unresolved regarding the specific calculations needed for the distance traveled by body x.
The discussion highlights the dependence on the specifics of the collision scenario, including the timing and spatial relationships of the bodies involved, which are not fully defined. There is also uncertainty regarding the assumptions made about the nature of the collisions and the objects involved.
MelissaSweet
Hi guys!
I was hoping that some of you smart guys and gals might be able to help me.
I'm looking for the simplest way to describe a series of collisions. Basically, an object colliding with another object, then a time delay and then another object colliding with the first two and so on.
Is there an easy way to calculate the effects, or must each function be performed separately?
Thanks!
Melissa
That description is too vague to allow us to help you: is this, say, for a computer game, or any other "rough" simulation ? Or is it for a calculation that needs some accuracy in its results ? What are the objects involved ? Neutrons ? Ping pong balls ? Cars ? Fish ? Customers ? Birds (with or without bird flu ?) ? Are there 5 of them, or 10000, or 10^20 ?
Oh, okay sweetie.
I'm looking at a 3-body collision. Body x is in a stationary frame relative to the observer. Body y is moving to intercept body x and body y2 will intercept xy shortly thereafter in an exactly opposite trajectory to y, stopping xyy2 relative to the observer.
How do you figure the distance x traveled?
Melissa
So, x and y are undergoing an inelastic collision ? (meaning, x and y get "glued together" on their interaction, right)
Can we approximate the bodies as mass points, or do we have to take their spatial extension into account ?
I will presume that we can do with mass points. In that case, the thing that prevails is momentum conservation.
Body x, in the observer's frame, has no velocity and hence no momentum. Body y has a certain mass and velocity, and hence a certain momentum.
The total momentum of this system (xy) is then simply the momentum of y, which should be, after collision, equal to the momentum of the entire system xy (with mass = mass of x plus mass of y).
This allows you to calculate the velocity of the xy system.
Next, you do the same with the collision of (xy) and y2. Conservation of momentum will allow you to say what will be the final momentum. Now, if y and y2 have equal masses, and have opposite velocities, you can already see that the final momentum will be 0.
However, to know exactly the *trajectory* of x (which will start moving upon the first impact, and stop at the second impact), you'll have to say exactly when or where the first and the second y will hit. This is in the details of the description of your problem.
cheers,
Patrick.
Hiya Patrick,
I like that name (being of Irish descent myself). In fact I found a four-leaf clover in my yard just yesterday so I'm really feeling the luck o' the Irish is with me! o:)
Anyway, yes. You can presume the problem in point masses (but it's not pointless!) and inelastic collisions.
y and y2 are intercepting x in equal and opposite trajectories, but y2 is initially farther away from x than y is.
I know the trajectory of x will be in the same trajectory as y, but what I need is a formula to determine the distance x travels in this trajectory relative to the observer. I believe this formula must incorporate a function of time, but I don't know how to do it.
f=ma just tells me that overall the system is stationary to the observer, but obviously x must move some distance. How do I determine that distance?
Thanks!
Melissa
cheers,
Patrick.
Patrick,,your explanation is cool.
I just got to ask one thing ...why do we always have to conserve momentum during collisions...isn't there any else way out to solve them..I actually solved such questions many years before,,so may be point is missing somewhere.
Well, if you know WHEN y hits x and you know where y2 is AT THAT POINT, you now have x (in the couple xy) moving from that position onwards with the velocity you can calculate, and y2 moving towards xy with its initial velocity.
That's a problem of the kind: train A leaves station D at noon, towards station E, and has speed v1 ; train B leaves station E, also at noon, towards station D, with speed v2. At what moment, and where, does train A cross train B on the track between station D and station E...
Patrick,
Okay, that's as I thought. There isn't an easier way. Each calculation is a separate function.
Thanks
Melissa
  • · Replies 35 ·
9K
