Calculating Electric Field from a Charged Filament
8 replies · 19K views
A long glass filament carries a charge density [tex]\lambda = - 2.7{\rm{ nC/m}}[/tex] . What is the magnitude of the electric field 0.67 mm from the filament?
Did I do this problem correctly? I'm guessing not because my answer has an extra /m . Shouldn't it simply be N/C?
[tex] E = \left| {\frac{{k\,d\lambda }}{{r^2 }}} \right| = \left| {\frac{{8.99 \times 10^9 {\rm{N}} \cdot \frac{{{\rm{m}}^{\rm{2}} }}{{{\rm{C}}^{\rm{2}} }} \cdot - 2.7{\rm{ nC/m}} \cdot 10^{ - 9} {\rm{C/nC}}}}{{{\rm{0}}{\rm{.67mm}} \cdot 0.001{\rm{m/mm}}}}} \right| = 54000000{\rm{ N/Cm}}[/tex]
Isn't the filament a long line of charge? So, the field strength is proportional to 1/r.
Basically, except isn't E=2*k*lambda/r? I think you missed a '2'. Your equation is for the infinitesimal element of E before it is integrated.
Thanks. Ok, then would it be:
[tex]E = \left| {\frac{{2k\lambda }}{r}} \right| = \left| {\frac{{2 \cdot 8.99 \times 10^9 {\rm{N}} \cdot \frac{{{\rm{m}}^{\rm{2}} }}{{{\rm{C}}^{\rm{2}} }}\left( { - 2.7{\rm{nC/m}} \cdot 10^{ - 9} {\rm{C/nC}}} \right)}}{{{\rm{0}}{\rm{.67mm}} \cdot 0.001{\rm{m/mm}}}}} \right| = 72000\,{\rm{N/C}}[/tex]
Where did E=2k*lambda/r come from? Is this just a standard formula I can use as a starting point, or would I be expected to integrate and come up with this formula?
I know it's k*lambda/r. I had to look it up to get the numerical factor of 2. Just looking at the problem statement, it doesn't look like a 'derive the formula' type problem, though the derivation isn't that hard. I would suspect the formula is in your book or notes and you can just use it. Check though.
Thanks. I'd like to understand how to do it even if we can start with the formula. Awvvu's link shows how. Stay tuned... I might have questions about that link.
I though of another way. From our class notes, we did the integration of the same problem, except the filament had a finite length. The formula was [tex] {\overrightarrow {E_y } = \frac{{k\lambda L}}{{y^2 \sqrt {1 + \left( {\frac{L}{{2y}}} \right)^2 } }}}[/tex]
To convert this to use for an infinite length:
As L approaches infinity, the 1 under the radical becomes insignificant, allowing me to eliminate it and replace [tex] \sqrt {\left( {\frac{L}{{2y}}} \right)^2 } [/tex] with [tex]{\frac{L}{{2y}}}[/tex].
. Then my L's cancel leaving me with [tex]\frac{{2k\lambda }}{y}[/tex]
Thanks for checking my work. I probably would have submitted my original attempt if the two of you didn't correct me.
