Calculating Energy Stored in a Parallel-Plate Capacitor
  • Thread starter Thread starter yayovio10
    Capacitor Energy
20 replies · 3K views
yayovio10
A parallel-plate capacitor with plates of area (0.5m) * (1m) has a distance separation of 2 [cm] and a voltage difference of V = 200 [V], as shown in Fig.
a) Find the energy stored
b) keep d1 = 2 [cm] and the voltage difference V, while increasing d2 = 2.2 [cm]. Find the energy stored (hint hint u=1/2CV^2)
but how if d1=2 and d2=2.2, can you still use the capacitor formulas even if its a uneven capacitor?
can you give me a little example please, i just cannot imagine since one side is uneven :(
so for example i will use this formula E = Δ V / Δ d, and by dividing the plates in very tiny plates
i can now write E as E = ∑ (Δ V / Δd), but since we V is constant E= V (∑ (1/Δd)) so this will be the same as E=V∫((1/dx)) from d1 to d2 where d=x?
is this approach correct? and then calculate the charge and then the energy?
ok so i was wondering if so for example i will use this formula E = Δ V / Δ d, and by dividing the plates in very tiny plates i can now write E as E = ∑ (Δ V / Δd), but since we V is constant E= V (∑ (1/Δd)) so this will be the same as E=V∫((1/dx)) from d1 to d2 where d=x?
Looks unwieldy. What happens to your stack of plates when you reach d = 2cm?
How about this instead: compute the E field as a function of x along the bottom plate: x = 0 on the left and x = 0.5m on the right. Compute the energy in a typical volume dx d(x) 1m and integrate.
the idea is that i can divide the plates in very tine ones and will use this forumula
[tex]Q \equiv εA(Δ V / Δd)[/tex] and will set [tex]A\equiv dxdy[/tex] and [tex]d \equiv dz[/tex]
so the new equation will be like
[tex]Q \equiv εV \int_0^1 {dx} \int_0^.5 {dy} \int_a^b{1/dz}[/tex]
where [tex]a\equiv2[/tex] and [tex]b\equiv2.2[/tex]
and then use [tex]u \equiv QV(1/2)[/tex] is this correct?
Kinda... why introduce the charge?
You want to use ##U=\frac{1}{2}CV^2\implies dU = \frac{1}{2}V^2\;dC##
Put the x-axis in the direction the separation of the plates varies.
Divide the width into strips L=1m long, and dx wide... this is a row of parallel plate capacitors in parallel... you know how to find the capacitance of a parallel plate capacitor.
If we put the x-axis so the separation goes like: d(x=0)=2m and d(x=0.5)=2.2m, you can find an expression for d(x)
From that, and knowing that V is the same for all the capacitor elements, you can find:
dC= (the capacitance of the element at position x)
... get this from the expression for the capacitance of a parallel plate capacitor.
Use that to get an expression of form: ##dU = f(x)\;dx##, and integrate both sides.
There's no need to compute capacitance, though it can be done that way of course.
The direct way is to use the formula energy = energy density times volume. What is the energy density of a field E in vacuo?
using [tex]C\equiv \frac{εA}{d}[/tex] where A= area of plates and the distance is a function of x [tex]d(x) \equiv 2 + 0.4x[/tex]
we get
[tex]C\equiv ε \frac{\int_{0}^{1}dy \int_{0}^{.5}dx}{\int_{0}^{.5}(2+.4x)dx}[/tex]then substituting in [tex]U \equiv \frac{1}{2} ε V^2 C[/tex]
we can get
[tex]U \equiv \frac{1}{2} ε V^2 \frac{\int_{0}^{1}dy \int_{0}^{.5}dx}{\int_{0}^{.5}(2+.4x)dx}[/tex]
is this correct?
is this approach correct in my last reply?
Simon Bridge said:
I don't think so - you have too many integrals.
where am i wrong?
Why not go step-by-step through the suggestion in post #11?
you have:
1. expression for d(x): ##d=2+2x/5## (better to avoid decimals in equations - if you can)
You still need the others:
If the plates are 1m long and dx wide - what is their area?
Therefore:
2. dC=
Therefore:
3. dU=
ok so after trying with my friend we got this,
is this right now?
you have:
Therefore:
2. dC=
Therefore:
3. dU=
is the last reply right?
