Calculating Eye Resolution at Different Distances
  • Level: Undergrad
  • Thread starter alex_boothby
    Eye Resolution
5 replies · 4K views · last reply
alex_boothby
hey how would you work out resolution of an human eye at defeerent distances looking at 2 lines 0.25mm apart?
cheers alex
I guess you just vary the distance of your eye to the two lines, starting from a point where you can see the 2 lines distinctly. The exact point where the two lines seem to merge and you cannot see the space between them, you note this distance ,d. Since d is very large compared to the width, the angle between the 2 lines is approx (sin(a) = 0.25/d)
The angular resolution of the eye would therefore be (a) That is, you can only see distinctly a width that sweeps out an angle (a) or more from where you are standing.
hope this helps.
if you want the resolution in terms or the actaul width of the object you are observing, it is width= (distance of your eye to object) x sin(a) which you found earlier.
Eye resolutions for various animals.
  • Table 3.1 listing maximum resolvable spatial frequency in cycles per radian and equivalent inter-receptor angle in degrees for animal eyes, including eagle, man (fovea), octopus, jumping spider, cat, goldfish, dragonfly, rat, bee, scallop, flatworm and others, with method and reference columns.
ne1 kno much about resolution when u change the lux in the surroundings?
Unfortunately, my eye resolution isn't good enough for me to read that. :frown:
