Calculating Force and Acceleration for a Yoyo and Clock
8 replies · 2K views
Julia Darko
A yoyo is spun with a radius of 0.5m. It reaches a velocity of 30m/s. What is the force if the yoyo is 0.3kg?
A clock has a hand with 0.3m long and 0.5kg. It takes 60 seconds for 1 revolution. What is its acceleration? What is the force?
If you have any tips or instructions, please comment,
Ac= v^2/r
2(3.14)r/t
F=ma
I attempted to solve the first one and I got 1800 m/s and 540 Newtons, but I feel this is wayyyyyyyyyyyyyy off. Please save my soul someone.
Ac= v^2/r
2(3.14)r/t
F=ma
The 540 N looks to be in the right ballpark, so that's not so worrying. To say more we'll have to see the details of how you arrived at that value.
I'm not sure what the 1800 m/s could pertain to. It doesn't seem to be an answer to a question posed in your problem statement.
For my first equation, I plugged in A=(30)^2/.5 and got 1800 m/s^2. Then I used F=ma... F=(.3)(1800) and got 540N. I wasn't there when this was taught so I'm not sure if I'm heading in the right direction. :/
This is not at all clear. A yo-yo has two radii - its outer radius and the radius of its axle.
What force? Is this perhaps the tension in the string as the yo-yo descends under gravity, when it has reached 30m/s?
Edit: Oh I see, it may be a yo-yo but it's being treated as just mass on the end of a string of fixed length. (Are you sure that's the right interpretation? It's not what is usually meant by a spinning yo-yo.)
But is this in the presence of gravity? If so, for the force to be constant it will be spun in a horizontal plane, and gravity will affect the tension. So my question becomes whether the force is supposed to be just the centripetal force or the whole tension.
Okay, that's fine and makes sense now that the details are there. Your results are fine.
Now, what's your approach for the second question?
I believe that the yo-yo in this case just represents a weight on the end of a string, said weight undergoing circular motion with the string as the radius.
Yes, I realized just after your previous post that that's how it was being interpreted. But please see my follow-up question in post #4.
Well for the second equation I just used the 2πR/T, so 2(3.14)(.3)/60seconds=.0314m/s. Then I plugged that into A=v^2/r, A=.0314^2/.3 and got .00328 m/s^2. Then, I plugged that it F=ma.. So F=(.5)(.00328)= .00164 N.
Okay, the calculations look fine. You may want to make sure that the number of significant figures in your final results correspond to the number of significant figures in the given data.
