Calculating Force on a Diving Bell Port at 147m Depth | Simple Pressure Problem
  • Thread starter Thread starter BuBbLeS01
    Pressure
The problem involves calculating the total force on a circular port of a spherical diving bell submerged in the ocean at a depth of 147 meters. The relevant parameters include the diameter of the port and the density of seawater.
  • Participants discuss the relationship between pressure, force, and area, with some questioning the calculations and assumptions made regarding pressure at depth.
There are various attempts to calculate the force, with some participants noting discrepancies in results. Guidance has been offered regarding the need to consider atmospheric pressure in addition to the pressure from the water column. Multiple interpretations of the problem setup are being explored.
Participants mention assumptions about the presence of air in the diving bell and the need for unit consistency in calculations. There is also a reference to a similar problem, suggesting potential confusion or overlap in understanding.
BuBbLeS01
A spherical diving bell containing a camera is in the ocean at a depth of 147 m. It has a flat, transparent, circular port with a diameter of 12.7 cm. Find the total force on the port (use ρsea water = 1025 kg/m3).
p = po + pgd
P = F/A
F = pA
So do I find the total pressure and then multiply it be the area? I get a really big number (2.00 x 10 ^ 8) which doesn't seem right?
No I don't think so cause it is worded differently and in our class they are all worded the same just different numbers...but that's weird its almost identical!
yea that answer isn't right...I just tried it :(
does anyone know how to do this?
Sorry - I thought your comment meant you had solved it!
The area of the window is A = pi r^2
There is a column of water on top of it 147m high
So the volume of water sitting on the window is V = pi r^2 * depth
Add the density of water and you get the mass of water on the window.
V = pi * (0.127/2)^2 * 147 = 1.89m^3
Density is 1025 kg/m^3 so mass of water is 1900kg
Total force is F = mass * g = 18.7KN
Note there is also an extra 1 atmosphere of pressure pushing down on the surface of the water, but there is also an atmosphere of pressure inside the bell pushing out which cancel out.
thats ok...but its telling me that's incorrect?
this is the msg it gave me...
Calculate the total pressure at the given depth by adding up the atmospheric pressure (1.01e5 N/m2) plus the pressure due to the sea water. This assumes that there is no air in the bell, (probably a bad assumption).
Alternate method - the weight of the column of water = m g h = 1.47MN
Area A= pi r^2 = 0.0127m^2
Force = pressure * area = 1.47MN/m^2 * 0.0127m^2 = 18.67N
EDIT - then just add atmospheric pressure to the water pressure, answer should be 20KN.
I'm having deja vu and amnesia at the same time...I think I've forgotten this once before.
LoL...
I don't understand I enter 0.02 N (it doesn't recognize units like KN or MN) and it says incorrect??
20 KiloNewtons ie 20,000N or 2E4 N
  • · Replies 23 ·
9K
  • · Replies 17 ·
