Calculating Force Using Young's Modulus
To calculate force using Young's modulus, the relevant formulas include stress (σ = F/A) and strain (ε = ΔL/L), leading to the expression E = FL/(AΔL). The discussion highlights a student's attempt to find force, resulting in a calculation of 9812.5N, which was significantly off from the teacher's answer of 981N. The discrepancy is attributed to a potential misplacement of a decimal point. Participants emphasize the importance of clearly stating the problem and showing calculations to identify errors. Accurate calculations and understanding of the formulas are crucial for solving problems related to Young's modulus.
chriscarson
Calculating Force when having the area .
How can you Calculate Force ?
I'm not sure what the question is specifically. We have ##\sigma = \frac{F}{A}## and ##\varepsilon = \frac{\Delta L}{L}##, along with the definition of Young's modulus, ##E = \frac{\sigma}{\varepsilon}##.
You can put these into one expression, namely ##E = \frac{FL}{A\Delta L}##.
Likes chriscarson
etotheipi said:
I'm note sure what the question is specifically. We have ##\sigma = \frac{F}{A}## and ##\varepsilon = \frac{\Delta L}{L}##, along with the definition of Young's modulus, ##E = \frac{\sigma}{\varepsilon}##.
the question is to find the force
So are you after ##F = \frac{AE\Delta L}{L}##?
Likes chriscarson
well i have all those values so i can give it a shot , although our teacher give us homework that we didi nt had lesson on ,
thanks
was very close the teacher s answer was 981N mine was 9812.5N
That's what's called being out by a factor of ten. Can you find the reason for it?
Likes chriscarson
i know you can round it to 3 significant figures but nothing about factor of ten.
You should post your calculation along with a statement of the problem. My guess is you've misplaced a decimal point somewhere.
Likes chriscarson
ok it seems it s important to write the problem
  • · Replies 29 ·
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 19 ·
